3 members (Otto Skorzeny, Southerntruck, Peggy M), 29 guests, and 9 robots.
Topics128,013
Posts1,055,312
Members48,419
#633969 04/01/2010 4:21 AM
I have a '49 half-ton, with a late model 235 engine, and original stomp starter converted to 12 volts. Occaisionally, when I stomp on it to start, I get an awful grinding/screeching noise which I assume is the starter gear not engaging the flywheel properly. If I wait a couple seconds and try it again, the starter engages correctly and the engine fires right up. I can think of a couple possible explanations:
A) All Stovebolts do this. It's part of the fun.
B) Something is worn out and needs to be replaced
C) I'm either stomping too hard or not hard enough, and this is causing the starter motor to energize before engaging the flywheel.
Thoughts? It doesn't seem to be hurting anything, but it sure scares the people around me.
norcal49er #633978 04/01/2010 4:53 AM
It could be slop in the mechanism causing, as you said, the starter motor to energize before engaging the flywheel.
Another thing to check is the fly wheel. These engines always stop at one of 3 places. You might have worn teeth in those 3 places on the flywheel. If so the ring can be rotated.
Cletis #634021 04/01/2010 1:14 PM
Cletis,
What do you mean by slop in the mechanism? Mine does exactly the same thing. What would I look for to find the slop?
Thanks.
Dale
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
di1953gmc #634031 04/01/2010 2:20 PM
Sounds like the starter drive is worn out. Probably time for a rebuild.
di1953gmc #634108 04/01/2010 6:48 PM
Originally Posted by di1953gmc
Cletis,
Thanks.
Dale
The arm that pushes the button has a fork on the end inside the starter. The fork ends have pegs that ride in a groove on the bendix. These pegs and the groove get worn. This could cause the start button to engage before the gear teeth are meshed.
Cletis #634232 04/02/2010 3:33 AM
Makes sense. I don't think the problem is the flywheel or the starter motor gear. I inspected both of them closely when I overhauled the engine and transmission. There was no obvious signs of wear. Can the parts you described be replaced? Do on-line vendors sell them? Thanks.
norcal49er #634250 04/02/2010 4:40 AM
I
I Offline
Perhaps the bendix spring is worn and not functioning properly.
