Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Shade Baby), 21 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#63226 07/20/2006 4:28 AM
Apprentice
Apprentice
i have recently finished rebuilding my 350, and i am in the process of trying to get it to run. I put the drill on the oil primer and watched the rocker arms. The driver side worked really well, oil all over the place. However the passenger side had no oil coming out of the rocker arms (pushrods). Help! Help! Help!
thanks
#63227 07/20/2006 4:40 AM
You are using a oil priming tool( or a cut down dist ) If you have oil going to one side it may take a bit. I use a big drill as the small ones seem to have trouble getting enough flow to oil the entire engine. Not saying that it wount but a larger drill will do it quick.
If you have oil to one side then it should get to other unless you have a passage blocked.
Assmly lube can do this.
