| | | Forums66 Topics128,012 Posts1,055,313 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63226 07/20/2006 4:28 AM | Joined: Apr 2006 Posts: 38 Apprentice | | Apprentice Joined: Apr 2006 Posts: 38 | i have recently finished rebuilding my 350, and i am in the process of trying to get it to run. I put the drill on the oil primer and watched the rocker arms. The driver side worked really well, oil all over the place. However the passenger side had no oil coming out of the rocker arms (pushrods). Help! Help! Help!
thanks | | |
#63227 07/20/2006 4:40 AM | Joined: Jul 2006 Posts: 47 New Guy | | New Guy Joined: Jul 2006 Posts: 47 | You are using a oil priming tool( or a cut down dist ) If you have oil going to one side it may take a bit. I use a big drill as the small ones seem to have trouble getting enough flow to oil the entire engine. Not saying that it wount but a larger drill will do it quick.
If you have oil to one side then it should get to other unless you have a passage blocked.
Assmly lube can do this. | | |
