5 members (WICruiser, TUTS 59, Napco Man, Ponchogl, stlcardinalsguy), 56 guests, and 2 robots.
Topics128,035
Posts1,055,564
#629858 03/18/2010 1:42 AM
Is there supposed to be a rubber seal or trim around the vent? Im getting water in from rain.
Yes, it goes under the vent. On mine there is a little "trough" where the gasket lays in on the cowl. The re-pop's may be cork or it could be rubber. I think you can order either one at some vendors.
Leo Offline
Moderator
Moderator
I happen to have one on order right now, with Jim Carter.
Y
Y Offline
Another source could be the drain hose? Easy fix.
Drain Hose!!????
Sugarlou,
There is a drain hose for the cowl vent that comes out at the top, center of the firewall. It's an angled piece of rubber hose about 6" long, and it drains any water that may seep in around the cowl vent.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
For what it is worth, I glued the rubber cowl vent seal in with the same 3M black glue that I used on the door seals. I did that two years ago, and it is holding up just fine.
Originally Posted by Samantha
Sugarlou,
Samantha
If you have a V8, it dumps the water right on top of your distributor!!(Dont ask how I know!) dang
More pix on Flickr.
Yes V8..I'll take a closer look today. Thanks all. Any Idea where to get the seal?
Sugarlou, there are a number of vendors who can help,try the links feature here.
I would recommend these guys. Steele Rubber.
They seem to be the best quality although they're not the cheapest.
Re; The drain tube dilemma, it's an easy fix.
Just find a piece of rubber hose the same I.D. and make a longer one which can be re-routed out the way of the Dizzy cap.
More pix on Flickr.
It's popular to do away with that drain hose on trucks with smoothed firewalls and in those cases you have to reroute the hose and have it exit somewhere else. Otherwise it dumps right in the middle of the floor. And you don't have to know how I know that little tidbit either but the firewall looked nice.
48 Chevy 3100 going back together with a 292 six and AX15 five speed.
Cool Gotcha thanks
