| | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#6301 11/18/2004 11:52 PM | Joined: Nov 2004 Posts: 122 Member | | Member Joined: Nov 2004 Posts: 122 | 1968 Chevy schoolbus. Previous owner claims the engine is a rebuilt 305 V-8. Most say that the 305 was an unlikely choice for a bus (me included) and may not have existed in 1968. Also, have heard that 305s were blue, while my engine has orange valve covers with chevrolet logos, and the block may have been orange at one time. Engine code on the VIN tag below the VIN is "DD". Does anybody know what motor this is? I posed the same question in the "big bolts" forum and got good feedback but no definitive answer. | | |
#6302 11/19/2004 12:27 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | In front of the right side cylinder head, there should be a flat spot with numbers stamped into it. You may need to clean and sand this area to make them ledgable. There is also a casting number behind the left head on the bellhousing flange. It won't tell you exactly which engine it is but it will give you a range of engines it is cast for. List the numbers here and the guys with decyphering books will tell you what you have, Scott | | |
#6303 11/19/2004 12:46 AM | Joined: Nov 2004 Posts: 122 Member | | Member Joined: Nov 2004 Posts: 122 | will do, thanks for the tip | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Get the code off the right front like bigtrucks posted & go to www.nastyz28.com It lists all the codes on chevy engines. I,d do a link but I don,t know how.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | | | |
