9 members (farmallb, moparguy, Opelika Tom, mk72, Otto Skorzeny, Oswald, Hush, RoadsScholar, 1 invisible), 181 guests, and 1 robot.
Topics128,089
Posts1,055,988
Members48,430
#63012 07/12/2006 3:29 AM
Junior Member
Junior Member
i have a '66 longbed that has a two-piece drive shaft. i've already had it shortened to fit when i swapped in a 350v8 with th350 tran.
now i'm merging what i have with a '64 fleet shortbed that has a 305v6 with 4spd. the '64 has a one piece driveline.
do i need a one-piece or two-piece drive shaft on a shortbed with th350 tran?
thanks
bill graham
#63013 07/13/2006 12:06 AM
If it's a truck 4 speed, you'll need the two piece.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#63014 07/13/2006 2:47 AM
With that set up you should be fine with a one piece driveline. The local driveline shop owner tells me a two piece isn't needed unless the driveline's total length will be over 70 inches,u-joint center to center.
speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#63015 07/13/2006 3:28 AM
There needs to be a slip joint somewhere in the driveshaft and it won't be into the rear of a truck 4 speed,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#63016 07/13/2006 2:42 PM
Junior Member
Junior Member
the slip joint with the current '66 with th350 config is at the tail of the tran.
the slip joint with the current '64 with 4spd config is built into the driveshaft, right behind where the u-joint bolts to tran.
to try to be more clear, i'm moving my 350/350 set-up from my '66 to the '64. along with everything forward of the bed and to include the 12 bolt rear that my '66 has. basicly what i did is strip the '64 and '66 to their frames and i'm bolting the best parts to the '64 frame and bed so i end up with a short bed big window.
fyi; alot of work
bill graham
#63017 07/13/2006 5:43 PM
I understand now, the TH350 would only require the one piece shaft, especially on a short bed, as long as it will fit through that rear crossmember safely. But if the 4 speed gets to do the duty, then you need the two piece,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
