0 members (),
128
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 11 New Guy | | New Guy Joined: Mar 2010 Posts: 11 | Is there supposed to be a rubber seal or trim around the vent? Im getting water in from rain. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Yes, it goes under the vent. On mine there is a little "trough" where the gasket lays in on the cowl. The re-pop's may be cork or it could be rubber. I think you can order either one at some vendors. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I happen to have one on order right now, with Jim Carter. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Another source could be the drain hose? Easy fix. | | | | | Joined: Mar 2010 Posts: 11 New Guy | | New Guy Joined: Mar 2010 Posts: 11 | | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | Sugarlou, There is a drain hose for the cowl vent that comes out at the top, center of the firewall. It's an angled piece of rubber hose about 6" long, and it drains any water that may seep in around the cowl vent. Samantha | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | For what it is worth, I glued the rubber cowl vent seal in with the same 3M black glue that I used on the door seals. I did that two years ago, and it is holding up just fine. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Sugarlou, There is a drain hose for the cowl vent that comes out at the top, center of the firewall. It's an angled piece of rubber hose about 6" long, and it drains any water that may seep in around the cowl vent. Samantha If you have a V8, it dumps the water right on top of your distributor!!(Dont ask how I know!)  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2010 Posts: 11 New Guy | | New Guy Joined: Mar 2010 Posts: 11 | Yes V8..I'll take a closer look today. Thanks all. Any Idea where to get the seal? | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Sugarlou, there are a number of vendors who can help,try the links feature here. I would recommend these guys. Steele Rubber. They seem to be the best quality although they're not the cheapest. Re; The drain tube dilemma, it's an easy fix. Just find a piece of rubber hose the same I.D. and make a longer one which can be re-routed out the way of the Dizzy cap. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Aug 2008 Posts: 38 'Bolter | | 'Bolter Joined: Aug 2008 Posts: 38 | It's popular to do away with that drain hose on trucks with smoothed firewalls and in those cases you have to reroute the hose and have it exit somewhere else. Otherwise it dumps right in the middle of the floor. And you don't have to know how I know that little tidbit either but the firewall looked nice.
48 Chevy 3100 going back together with a 292 six and AX15 five speed.
