| | | Forums66 Topics128,081 Posts1,056,069 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 59 | I purchased a offy valve cover, i installed the studs into my rocker arm assy. Now I'm at a stand still, Classic Parts did not mention I needed studs to hold the cover down. I assumed they came with it. Do they make a mounting kit? Something more nicer than a threaded bolt with a big washer. Thanks for any assistances. Patrick | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Ok - I'm trying to understand what you have. You installed the studs into your rocker assembly. That means you screwed the studs into the head and they are sticking up out of the rocker arm assembly. Did you put them in the center hole of each of the two assemblies? If so, the plain nut must be torqued onto the stud to help hold the rocker assembly in place. Now you should have the studs sticking up. Drop the Offy cover down on the studs and the gasket, then put the rubber gromets on the cover with a washer and install the nut to hold it down. Test run to see if it is sealed. If not, tighten the hold down nuts. That should do it. What's the problem?
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | No nuts to hold down the valve cover!!! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I got the stud kit with my valve cover supplier (Patricks) but that is a Wayne cover which I like a lot better than the Offy one. | | | | | Joined: Sep 2007 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 59 | I did not recieve the rubber grommets, oh well .I'll have something made to make it work. Thanks for the help | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | ryanb790,
Take the valve-cover and mounting-bolt to a good hardware store. They might have a grommet. I put a stainless steel washer (the diameter of the grommet) under the top nut (usually an acorn nut).
| | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | I bought the Offy cover in the 70s and it came with mounting studs and "grommets". The cheesey grommets they sent were actually short sections of a rubber hose that they roughly cut off to length. The inner diameter was the same as the studs and the outer fit somewhat tight in the holes of the valve cover. They gave plain nuts and flat washers.
This came brand new from Offenhouser.
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | There don't seem to be any really "right" grommets for those valve covers. I walked down the nuts-bolts isle in the hardware and poked around until I came up with something that fit in the hole, with a hole in it for the stud AND with a larger top to sit on top of the cover. I put a stainless washer on top of that with the bolt and it works well. Check the electrical grommets and the plumbing gromets. You should find something that will work.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Found some at NAPA in the part drawers. Rubber with a brass cetre. | | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | 6-cylinder Toyota part. Should be readily available. Found mine on a parts board at NAPA when I built my truck in 2003. | | |
