0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#629283 03/16/2010 2:41 AM
I purchased a offy valve cover, i installed the studs into my rocker arm assy. Now I'm at a stand still, Classic Parts did not mention I needed studs to hold the cover down. I assumed they came with it. Do they make a mounting kit? Something more nicer than a threaded bolt with a big washer. Thanks for any assistances.
Patrick
Ok - I'm trying to understand what you have. You installed the studs into your rocker assembly. That means you screwed the studs into the head and they are sticking up out of the rocker arm assembly. Did you put them in the center hole of each of the two assemblies? If so, the plain nut must be torqued onto the stud to help hold the rocker assembly in place. Now you should have the studs sticking up. Drop the Offy cover down on the studs and the gasket, then put the rubber gromets on the cover with a washer and install the nut to hold it down. Test run to see if it is sealed. If not, tighten the hold down nuts. That should do it. What's the problem?
No nuts to hold down the valve cover!!!
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
PapaJ #629373 03/16/2010 12:44 PM
I got the stud kit with my valve cover supplier (Patricks) but that is a Wayne cover which I like a lot better than the Offy one.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I did not recieve the rubber grommets, oh well .I'll have something made to make it work. Thanks for the help
ryanb790,
Take the valve-cover and mounting-bolt to a good hardware store. They might have a grommet. I put a stainless steel washer (the diameter of the grommet) under the top nut (usually an acorn nut).
I bought the Offy cover in the 70s and it came with mounting studs and "grommets". The cheesey grommets they sent were actually short sections of a rubber hose that they roughly cut off to length. The inner diameter was the same as the studs and the outer fit somewhat tight in the holes of the valve cover. They gave plain nuts and flat washers.
This came brand new from Offenhouser.
Greg_H #629650 03/17/2010 4:59 AM
There don't seem to be any really "right" grommets for those valve covers. I walked down the nuts-bolts isle in the hardware and poked around until I came up with something that fit in the hole, with a hole in it for the stud AND with a larger top to sit on top of the cover. I put a stainless washer on top of that with the bolt and it works well.
Check the electrical grommets and the plumbing gromets. You should find something that will work.
Found some at NAPA in the part drawers. Rubber with a brass cetre.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
6-cylinder Toyota part. Should be readily available. Found mine on a parts board at NAPA when I built my truck in 2003.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
