4 members (Oswald, rfs56trk, baldeagle, jasrking), 49 guests, and 1 robot.
Topics128,014
Posts1,055,332
Members48,419
#628671 03/14/2010 12:06 AM
I would like to get some comments on spray paints and primers to use on those parts that are under the truck or attached to the frame. What's best to use?
The best things in life are FREE!
53jimmy #628695 03/14/2010 2:43 AM
I have used many cans of the Rustoleum primer and had no problems. The Rustoleum gloss black is not bad. I have used Dupli-color and some others but I really don't see that much difference.... especially using it for what your talking about.
Achipmunk #629017 03/15/2010 5:35 AM
Rustoleum is fish oil based. Dupli-color is lacquer based.
Rustoleum primer is NOT sandable. On frame and suspension, use the Rustoleum gloss black. It will look great and be durable.
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
countilaw #629026 03/15/2010 6:02 AM
Rustoleum Auto primer is "VERY" sandable! It builds up and fills sand scratches very well. Eric
I was told that Rustoleum is now water based after the first of 2010 in Calif so I am sure it is the same all over the USA.
This was a Paint Dept head who works for OSH. hardware. He wasn't to happy about it as he redoes metal patio chairs and tables.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
Don G. #629049 03/15/2010 8:55 AM
I made brackets for my work cover and used Rustoleum Primer then sanded the brackets and sprayed them with Semi Gloss White Rustoleum.
62Blue
Don
62Blue
62Chevy in progress
Don G. #629258 03/16/2010 1:53 AM
I have had horrible luck with spray paint, I now paint everything with my spray gun. For brackets and frame parts I use single stage paint I mix myself at work. It sounds ridiculous but honestly it's not that bad. I have found spray paint to be very brittle after it is in the weather for a few years. I feel that the single stage paint lasts longer because of the hardener that is added in the mixing process. Of course most of you live in the south and I live in New England, that's probably the problem. When I do use spray paint (which is not very often) I reach for duplicolor.
