3 members (Stovebolt48, 1955 1 Series, Charles in CA), 114 guests, and 2 robots.
Topics128,189
Posts1,057,337
Members48,469
I am baffled. The 207 c.i. in my 1934 Master keeps stalling after it warms up after I've been driving for about five to ten minutes. I've trimmed out the carburetor (set the low speed jet and throttle control). The car will idle fine but once I get it into gear, it stalls out. Could it be the distributor vacuum advance?
Ex Hall Monitor
Ex Hall Monitor
Does it act like it's running out of gas? If so it could be a weak fuel pump (vapor lock). The engine heat vaporizes the fuel and the pump is too weak to overcome it. Just one possibility.
Did you set the timing with a light ?
Pete
Vapor lock sounds like it. We had the same thing happen with my brother's 1962 Chevy station wagon. I have a new fuel pump on the shelf. I'll replace the old one and see if it fixes things.
As for the timing, my Dad and I set the timing using a light about six months ago... I'll check it also.
A bad coil can start to fail when it gets warm. I thought I would give you something more to worry about!
1951 1 Ton Completed
I
I Offline
I had the same problem. I had a hard time tracing down the problem so I started to replace or rebuild just about everything bolted to the engine. It ended up being the distributor. I didn't rebuild it I replaced it instead. I never came to a conclusion as to why a distributor would do that.
The coil is new. The distributor is relatively new. We kinda did what Iron Clad did and began replacing parts. I'm thinking it was a vapor lock. I replaced the old fuel pump and the car seems to get past 10 minutes. never know, though. It could still be a distributor on the edge. Working on the '34 is still a blast, though, even with the gremlins.
