3 members (Gdads51, Gib70, 1 invisible), 86 guests, and 0 robots.
Topics128,078
Posts1,055,935
Members48,430
Half my inside windshield trim clips are broken or missing. Searching old posts indicates no identified source of these clips. Anyone found a source?
Chuck
Best bet is some used from the parts wanted section.
Apprentice
Apprentice
I got mine from Mr. G's. Go to the web site & you can compare what you need to what's available. Steve.
Is this the place you're talking about?
http://www.mrgusa.com/index.html
....doggone Chuck, you mean we're suppose to have some "clips" on the windshield trim??? Mine didn't have ANY!!! ..... and I'm about ready to put my windshield and trim in.
Mmmmm, I better follow this post!
Any body got a picture or one??... so I'll know what it looks like...and what it does.
Alvin, some people have indicated they are to hold the windshield trim away from the window around the defrost vents. The few clips on my trim were also at the top so either they were installed wrong or more likely, they keep the trim properly spaced and keep you from getting a wave effect by drawing the screws down too tight.
Chuck
....makes sense Chuck... and now that you mention it I do believe I had ONE rusty clip that was somewhere around the defroster vent?
Sooo, anyone. Does the clips go all the way around???...OR just where the defroster vent is at??
..and where has anyone found them?? If you tell me I'll buy you a hot dog and Pepsi.
Alvin
12 clips total.Mine has 8 metal clips - 6 across the top 1 on either side pillar. On the bottom is 4 wire clips - 1 on either side of the defrost vent . The wire clips have some spongy rubber molded on to them.I imagine the spongy rubber clips are to keep the defrost air from escaping around the inside of the trim.These are original and I have no idea where to get replacements. 52 GMC . Hope that helps
That info helps me. I had 4 of those spongy rubber clips you describe. The rubber was really nasty and I didn't realize there was a clip inside- they are gone now. It makes sense what you said about the defrost. Mine didn't have outlets but the rubber was placed about where they would be.
Chuck
avlin pm sent
Steve
Moderated by  ndkid275, Phak1
