4 members (tclederman, Peggy M, Cletus1950, Charles in CA), 139 guests, and 13 robots.
Topics128,106
Posts1,056,217
Members48,436
#62574 07/05/2006 12:19 PM
Hey guys,
The instructions in the maunual say to use a centering guiode to reinstall the timing gear cover on a 216 to prevent the seal from leaking. Where do I get one of these?
Rich
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
Use your balancer! Place timing cover with a few screws finger tight then slip on the balacer, the snout will correctly center the cover.
1946 1/2-Ton Chevy
Thanks....that makes sense.
1953 3/4-Ton Chevy
More pix
RB53
Ex Hall Monitor
Ex Hall Monitor
I used a piece of PVC pipe, wrapped with tape to the correct diameter which I slipped over the shaft. Worked for me. Be sure to use teflon tape or another sealer on the threads of the bottom two bolts or they will leak oil.
The diameter of the balancer where it fits in the seal is the same as a SBC, so if they make a SBC timing cover centeror, you can use it.
#62579 07/06/2006 12:25 AM
SBC??
1953 3/4-Ton Chevy
More pix
RB53
#62580 07/06/2006 12:42 AM
Small Block Chevy
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
ohhhhhh!
1953 3/4-Ton Chevy
More pix
RB53
If it isn't too late, now is the time to pull the front bearing cap and thread the holes so you can bolt the timing cover from the outside instead of having to pull the pan next time. (unless someone already did that for you).
As Tiny says, don't forget to put silicone on the threads of the bolts so they don't leak. I think Permatex 2-A or 2-B is specially made for threads- it is a non-hardening black goop and works great!
You can also use regular RTV-Blue o Red or whatever you've got lying around.
Got some thread sealer today. I will be awat the weekend but I will start reassembly next week. I will post some pics of my fresh clean 216.
As always thanks guys!
1953 3/4-Ton Chevy
More pix
RB53
