0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | Hey guys: Question
I have a fully restored '53 3100. Truck was a restored a few years ago and hasnt been driven much since. Everything in front of, and including, the firewall was painted. New wood in the bed, chrome, etc., however, the body man did not paint under the cab or the bed. Its still original under there and looks kind of bad from the back. How hard would it be, or how costly, to go back and spray under the bed (frame rails, rear end chunk, spare tire hardware, etc)
It doesnt seem like it would take an experienced body man too long...
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I f you would get your body man to remove the bed, which isn't all that hard, painting will be considerably easier and probably applied much nicer then with the bed on.
Drew
| | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | True. Can the bed be lifted w/o taking out the wood? Its been a while since I've worked on it, I cant remember
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Its the clean up and prep that will take time.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Sure.
It should just be four bolts and tail light wires. If you want to take the fenders off, that's just more screws. I hope your running boards aren't welded to your fenders like mine were.
Dave
| | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | Nah, running boards are bolted. (Rear fenders are fiberglass anyways)
It doesnt need to be show quality, just something better than 57 year old brown rust color and cobwebs.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | .... do it once and do it right. And the only way to do that is to remove the bed. Not costly but a little time consuming.
If you can be happy with it just pressure wash, rub-a-dub and then put some POR15 on all you can get to. This may serve your purpose?? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | "fully restored" wouldn't that include all the paint? Reminds me of the mechanics sign.
We can do it right - $50 per hour We can do it fast - $100 per hour We can do it half fast - $75 per hour
You should be able to remove the four bed to frame bolts and the taillight wires and four guys can lift the bed wood and all. | | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | Our truck even got a new bed, but for some reason, our guy didnt paint under the bed or the cab (fully restored wasnt the best wording) I guess he cut a couple of corners...oh well
I researched the POR15...can anyone voice their experiece with this stuff?
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I guess he cut a couple of corners...oh well Reading that sure makes me glad I did everything myself. Take a look at Zero Rust for chassis painting as it's a bit more user friendly.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I am using POR-15 and I love it. Follow the directions and make sure you don't get any on you or you will wear it for a few days. It doesn't like the sun and if you want to top coat it you need to dust it with primer as stated in the directions. It is hard stuff. I haven't seen any down side yet but someone that has a longer track record with it will chime in. | | |
