2 members (Nick in Manitou, 1 invisible), 342 guests, and 7 robots.
Topics128,159
Posts1,057,039
Members48,460
Hi all,
In need of a new/rebuilt master cylinder for 1950 3100; assuming everything on the truck is original or nearly so. Contemplating buying an entire brake system kit, (shoes, hoses, etc.) as well as a complete MC unit.
Any online stores Stovebolt posters recommend for this sort of thing? I won't be doing this work myself, and don't want to buy CRAP.
Mabel and I both thank you in advance for any advice and support.
I always try my local parts houses first. Our CarQuest still has "books" to look up old parts in and they can usually get them overnight. They even had a master on the shelf for my 64 2 ton,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Riding in the Passing Lane
Kanter auto products has complete kits, but like Scott I get my parts from Carquest. Ive had good luck with there linings. Some of them you get now are hard & take a lot of pedal pressure to stop. Often you can rebuild the master cyl. & wheel cyls. yourself.
1972 Chevy c10 Cheyenne Super
That year of 3100 you are using the "huck" brake system. Since you are doing the complete brake system, I would seriously consider upgading your brakes to a newer version even if it's only replacing the wheel cylinders with a '51 set. You'll find the newer cylinders are much cheaper then the "huck" cylinders. Check the Tech Tips here for ideas.
Drew
Good point Drew. I didn't realize it was a 50 with Huck brakes. The rules change. The parts stores don't show much for those any more. It would be best to change over to later model brakes or get the parts from specialty suppliers like Classic Parts or American classic.
Got all my shoes, springs, wheel cylinders, hoses & master cyl. rebuild kit from Jimmy @ Jim Carters Truck Parts.
http://www.jimcartertruckparts.com/
Local NAPA carries most everything except for the return springs if I remember correctly. Jimmy just beat their prices.
Hank
1951 restoration on website
http://www.hanklong.com
