1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | What would the tread with be for a 6.50 tire ?
Would a 215 radial tire be about the same width ?
I will be buying tires for my 54 3100 with original equipment...
Thanks in advance...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | go to www.randysringandpinion.com and use their calculator.215mm is 8.4 inches width. or try this site use the length conversion chart. 165mm seems to be 6.4 inches.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you go to the Tire Rack and sort by size, you will see all the specs on various makes of tires. They vary somewhat with style. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I have 215/85-16 T/A commercial on my Suburban and I like the look and the ride. | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | I had already researched the conversion chart... That just told me what the width of the tire was and not the actual tread width...
I found online a site that told me all the dimensions but the tread width...
Emailed a couple of tire sites waiting to hear back...
Tire stores around here seem to have a shortage of the 215 to measure... Lots of 225 and up...
It seems the best size for radials is the 215/85-16 as cletis posted... I will be going with the LT type...
Thanks for all the replies...
| | | | | Joined: Jul 2009 Posts: 70 New Guy | | New Guy Joined: Jul 2009 Posts: 70 | here is another place that has charts that is easy to compare tread width sizing. Bias are noticeably narrower than radial. widewhitewalltires.com | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do they list 16" 6-ply bias and 16" LT radial (with blackwalls, if someone is interested in original appearance)?
