3 members (baldeagle, Mike B, Hotrod Lincoln), 83 guests, and 1 robot.
Topics128,026
Posts1,055,409
Members48,422
#623307 02/25/2010 3:20 AM
What would the tread with be for a 6.50 tire ?
Would a 215 radial tire be about the same width ?
I will be buying tires for my 54 3100 with original equipment...
Thanks in advance...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
go to www.randysringandpinion.com and use their calculator.215mm is 8.4 inches width. or try this site use the length conversion chart. 165mm seems to be 6.4 inches.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
If you go to the Tire Rack and sort by size, you will see all the specs on various makes of tires. They vary somewhat with style.
1951 1 Ton Completed
I have 215/85-16 T/A commercial on my Suburban and I like the look and the ride.
Cletis #623415 02/25/2010 10:19 AM
I had already researched the conversion chart... That just told me what the width of the tire was and not the actual tread width...
I found online a site that told me all the dimensions but the tread width...
Emailed a couple of tire sites waiting to hear back...
Tire stores around here seem to have a shortage of the 215 to measure... Lots of 225 and up...
It seems the best size for radials is the 215/85-16 as cletis posted... I will be going with the LT type...
Thanks for all the replies...
healingbear,
I do not know the tread width of a 6.50x16" bias tire; however, 6.5 refers to the tire tube section .
The tread width of a Cooper SRM II Radial LT (Light Truck) 215/85/16 is 5.93". A narrower rim would result in the same tread width, but would also result in a narrower section width and a higher/wider loaded diameter (a narrower and "faster" tire).
As has been stated many times, from 10 or more feet, these tires look like bias-ply tires. I have had people look at the tires on my Suburban from a distance and tell me that they couldn't be radials (until they get close enough to read the word "radial" on the tire).
http://www.coopertire.com/html/tireselector_bySize.aspx?twtd=215&artw=85&rd=16
http://www.coopertire.com/HTML/products/tires_lighttruck.aspx?page=srm_2_radial_lt
here is another place that has charts that is easy to compare tread width sizing. Bias are noticeably narrower than radial.
widewhitewalltires.com
Do they list 16" 6-ply bias and 16" LT radial (with blackwalls, if someone is interested in original appearance)?
