| | | Forums66 Topics128,041 Posts1,055,481 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 4 New Guy | | New Guy Joined: Feb 2010 Posts: 4 | Just bought a 37 pickup and was wondering about interchange years on the front suspension? Can anyone give me the years of interchangability, spindle etc. Thanks Dale | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Welcome to stovebolt.
| | | | | Joined: Feb 2000 Posts: 5,197 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,197 | What are you wanting to interchange? Mine has the whole axle assembly from a '55 under it I think, really not sure what year it its, just know the king pins were from that year.
Joe | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I've got a 54 front end under mine. Everything bolts up. The actual part number for the 37 axle is not the same as the 41-55 1st, but the axles and the parts will change out. The same tie rod works on all of the front ends.You will have to maintain the 37-46 pitman arm. You can also up grade the steering box from 37 to a 41-46 and another smart thing to do is up grade the tierod ends. The main difference in the front ends is the axle size and the king pins. The 41-54 axle is heavier and the king pins larger. Both of these differences make the front end a better, stronger and more safe front end.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
