8 members (Robert Crandall, Wayne67vert, Uncles51, kades51, Hotrod Lincoln, jay d, Hanks custodian, Rusty Heaps), 79 guests, and 2 robots.
Topics128,041
Posts1,055,480
Members48,424
#623756 02/26/2010 2:45 PM
1 Offline
Just bought a 37 pickup and was wondering about interchange years on the front suspension? Can anyone give me the years of interchangability, spindle etc.
Dale
Welcome to stovebolt.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
What are you wanting to interchange? Mine has the whole axle assembly from a '55 under it I think, really not sure what year it its, just know the king pins were from that year.
Joe
I've got a 54 front end under mine. Everything bolts up. The actual part number for the 37 axle is not the same as the 41-55 1st, but the axles and the parts will change out. The same tie rod works on all of the front ends.You will have to maintain the 37-46 pitman arm. You can also up grade the steering box from 37 to a 41-46 and another smart thing to do is up grade the tierod ends. The main difference in the front ends is the axle size and the king pins. The 41-54 axle is heavier and the king pins larger. Both of these differences make the front end a better, stronger and more safe front end.
