Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Gdads51, ShopRag, baldeagle, Southerntruck, Otto Skorzeny, HandyAndy), 51 guests, and 1 robot.
Topics128,008
Posts1,055,285
Members48,418
#62337 06/28/2006 5:28 PM
I have my T-5 transmission installed in my 37 pick up. I must say that everything is coming along nicely - slowly, but nicely. I do have one problem I cannot solve so I bring it to the men of the square table (here) to seek help!! I do not need a "man law", just help!!! grin
I replaced the motor mounts on the bell housing just before the T-5 installation. This caused the engine/transmission combo to raise about 3/4 " in the truck. The motor mounts were in very bad condition (original) and really need to be replaced. This also caused getting the T-5 in the bell housing an unforgettable experience. Now, I find the T-5 to be about 3/8" above the floor board line of the truck. I have purchased a fiberglass 4 speed transmission floor board from Jim Carter and it fits perfect and clears the transmission except at the cut out at the 4 speed spot in the floor board - a hole about 6" X 8". Of course, I do not have a plate to cover that spot because one doesn't come with the floor board plus it would have to be 3/8" higher than the floor board or "hump up" 3/8". eek
Can anyone give me a suggestion as to how to handle this problem? Is there a floor board piece you know of that would work for me in this situation?
Thank you for any useful suggestions!!
Joe smile
#62338 06/28/2006 10:24 PM
Riding in the Passing Lane
Seems to me a guy could fabricate a cover out of sheet metal. Where does the shift lever come through. I used a hurst shifter boot on mine. These hardware stores now have metal in stock in various sizes & thickness.
1972 Chevy c10 Cheyenne Super
#62339 06/28/2006 11:22 PM
since we have carpet and insulation in the cab... don't laugh guyzzzzz
the oval ring that now holds the shifter boot is attached to the carpet. I cut a hole (3x4) in the carpet just big enough for the shifter stem. I stuffed foam (taper cut) in the shift boot to help
1. keep it's shape
2. block air from coming up into the cab. grin
I reused the steel cover and made a simple hump in front of the shifter to suit the shifter hole. the rear of the floor plate is flat. so unless you can fabricate a sheet steel or re-configure the small cover you cut out and do fiberglas work and build into the carter larger cover, 4 plate attaching nuts so you can always have the small cover bolts ready to screw into those 4 nuts. it makes for a very clean job. grin
make sure your T5 output U joynt (chevy 350) fits under that cover and does not hit on rotation, it should be angled slightly downward anyway.
Jim & Caroline
#62340 06/29/2006 12:42 AM
Don't know if this will be of any help but you can see my T5 installation and modification of the tranny cover plate in my gallery at:
http://community.webshots.com/user/Fla54Chevy3100
I used the stock S10 boot and would suggest you leave adequate room above the shifter to be able to remove it without tearing out your sound/carpet stuff. I know the s10 boot is a bit big but "easy access" was more important to me. The sm420 "hole" was simply covered with light gauge sheet metal. Your application may be different but you may get an idea from my application. Just my $.02, hope it helps.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#62341 06/29/2006 12:51 AM
Fla54Chevy3100 , need to add another / in front of community so the link will work
Great pictures and documentation by the way grin
"All right, they're on our left, they're on our right, they're in front of
us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC
#62342 06/29/2006 12:54 AM
Thanks....just saw that.....you guys are quick!!!!
#62343 06/29/2006 3:28 AM
Which style of bellhousing mounts does your truck use? The kind that bolts to the side of the bell or the kind the bell sits on? If it bolts to the side, could you slot the bolt holes some to gain the clearance? If it's the kind that it sits on, could you make new "thinner" ones?
Just throwing out ideas,
Scott
Also, when I rebuilt my 4400's floor and trans cover, the hump on the trans cover was rusted to the point that it required replacement. The old hump was almost the exact same size as a 9" X 13" cake pan. So I went to Wally World and bought the heaviest guage cake pan and welded it to my trans cover and no one is to the wiser. Maybe you can make your own cover from the baking isle of your favorite department store.
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#62344 06/29/2006 4:57 PM
Thanks everyone for your ideas and thoughts. With your help, I have figured out what I need to do.
The idea about adjusting the motor mounts is very good.
Joe smile
#62345 06/29/2006 6:08 PM
I have had a T-5 in my '50 and now a Tremec3550 and was able to use a standard flat floor without a problem. I also replaced the rear motor mounts but never had a clearance problem. The only other thing that comes to my mind is the condition of your cab mounts. If they are in poor shape, replacing them may give you some additional clearance. Good luck - the 5 speed is a great set up!
#62346 06/30/2006 11:19 AM
Arpee makes a really good point - if your cab mounts are rotted away, in effect the cab and cab floor are too low. It might be a can of worms replacing them, I'd think that the fender and hood alignment would be a problem if you simply jacked up the cab and replaced the mounts.
#62347 06/30/2006 11:01 PM
I really like the looks of the '37s and if you get too frustrated might consider trading my '51...
Seriously though, look at your cab mounts and your engine mounts first, it would be a shame to alter the floor pan if you don't have to. Replacing the cab mounts isn't a big deal and shouldn't throw off the geometry on the fenders.
I like the idea of using a cakepan! If not, fab up what you need with a welder!
#62348 07/01/2006 2:45 AM
The cab, hood, and fenders are all one piece if no bolts have been removed. Just loosen the core support bolts and the steering column to dash bolts and you can easily raise 1/2". This is shown of such a unit being set onto an S10 frame. Go to http:www.msnusers.com/Evanscars. Click on "pictures", "show photos", page 2, and S10 025.
Evan
#62349 07/01/2006 2:49 AM
Sorry about that, lets try http://www.msnusers.com/Evans cars
Evan
#62350 12/19/2006 6:56 PM
DW Offline
Evan, the link you posted doesn't seem to be working. Can you repost the pictures?
Dave
