8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62219 06/26/2006 10:28 PM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | I have a 51, 235 with hyd lifters. I have broken 3 seperate intake rocker arms # 2,5,6. Each after between 25-40 miles of driving. The engine runs great and I'm real happy with it. Except for the rocker arms of coarse. The push rods are not bent. Do you suppose the intake valves are sticking? I put Marvel in the oil and gas but in 25 miles another one broke. Any ideas? Thx.
Glenn, | | |
#62220 06/26/2006 11:19 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Are you sure you have hydraulic lifters? I thought that the only hydraulic lifters in 1951 were on powerglide equipt cars. | | |
#62221 06/27/2006 2:19 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If the intake rockers break it is usually due to old gas gumming the guides. How old is the gas?
See the USA in your vintage Chevrolet! My Blog | | |
#62222 06/27/2006 3:05 AM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | A pushrod will usually bend before breaking a rocker arm. My 38 bent two because of stuck valves. I had to drive the valves out with a hammer after pulling the head.
#62223 06/27/2006 3:21 AM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | How are you adjusting the valve lash? | | |
#62224 06/27/2006 4:34 AM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | 1. Yes hyd lifters. 51 car eng. w/pw 2. Gas is about 3 weeks old. New tank 3. I heat the eng up, adjust out all lash and then tighten 3/4 turn more. Some guys say adj. 1/2 turn and some say 1 full turn. Tech Article says 1/8-1/2 or your going to have http://centuryperformance.com/valveadjustment.asptrouble. So far I'm having trouble. The valve seems to be free. When I put in a new arm the valve moves freely.It is not stuck. Any ideas? | | |
#62226 06/27/2006 3:56 PM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | i don't think your suppose to tighten valves like that on these engines like you do on a 350 or the newer chevys...someone else will be along soon to confirm this..but i think you use a feeler gauge, warm up engine then re-set them again with feeler gauge...sounds like you have them to tight... | | |
#62227 06/27/2006 4:30 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | GEC52,
I tend to agree with Tiny...it seems the push rod would always bend before a rocker would break. If a valve seized in a guide tight enough to break a rocker arm, it doesn't seem like it would "unseize" by itself.
I would focus on the rocker arms themselves. Is the assembly getting the proper amount of oil? Could the engine have overheated at some point in its life and damaged the integrity of the rocker arms?
It sure seems like you are doing everything right in the adjustment department. When you replace the rocker arms that have broken, do they break again! Short of bottoming out a spring or having the valve kiss a piston, It would appear that the cause of the failure would be the rocker itself.
Stuart | | |
#62228 06/27/2006 5:00 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | This is just a thought but could it be the hydraulic lifters themselves causing this problem? | | |
#62229 06/27/2006 6:29 PM | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | You said: "I heat the eng up, adjust out all lash and then tighten 3/4 turn more."
Are you setting the engine to #1 TDC (Top Dead Center)and then to #6 TDC before you do any adjustment?
Also when adjusting to zero lash, loosen the adjuster and turn the adjuster to zero lash with your fingers, not a screwdriver. Then, using a screwdriver another 1/4 turn.
Sometimes weak lifters or lifters that have been "pumped out" will give a false reading of zero. When you turn the engine over without oil pressure the lifters loose oil.
Then, when you start the engine, after the adjustment, the valves are probably going to clatter because the lifters are not completely pumped up.
If you are sure that you have ADJUSTED THE VALVES CORRECTLY,
Run the engine, faster than idle, to build up the oil pressure and the lifters. The valves are going to be loud and noisey until the lifters are again fully "pumped up". You will find that after a few minutes or so, the valves will then start to quiet down.
My 235 has hydraulic lifters and if I turn my engine over by hand 2 or 3 times when I restart it the valves are noisey but then quiet down after the lifters are pumped up.
-Tom
1950 Chevy 3100 w/ 1956 235
#62230 06/27/2006 6:54 PM | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | Let's look at other areas - where are rockers breaking: towards one of the ends, or in the middle?
Are you seeing any unusual wear on the rocker arms where they connect to the head? Check the unbroken rockers for signs of wear.
Are you running a stock camshaft, springs and valves?
Have you confirmed you're getting oil to the rockers?
I can't imagine a rocker breaking unless it's sticking, holding the valve open, and having the piston smash back up and close it.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#62231 06/27/2006 6:57 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I think any GROSS error in adjusting the valves will make itself apparent in seconds, especially with hydraulics. Too tight and that cylinder goes on vacation. I don't think this is a adjustment issue...can't wait to see the outcome!
Stuart | | |
#62232 06/28/2006 4:35 AM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | I hear everything you all are saying. I think my adjustment may be alittle tight so I'll loosen to 1/4 turn. The broken arms 2,5,and 6 are all intakes. They all broke at different times and different places ie. the valve side the middle and the push rod side. The push rods are not bent. I replaced the push rods when I did the frame off. I didn't need to touch the short block. I did have the head gone thru. Could the push rods be too long? They are 11 1/4". Does anyone know the length of their hydralic push rods? They are the length of the old ones. The engine sat for 20 years. Could the metal crystalize? When its running it runs real good. More to follow.
Glenn, | | |
#62233 06/28/2006 5:23 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Glenn,
Have you broken a new rocker arm that you replaced? This would be a big clue. As I stated earlier, I think any mechanical binding or seizing or piston contact would result in a bent push rod. If the rockers have broken, something has happened to them at some time to weaken them.
Stuart | | |
#62234 06/28/2006 2:50 PM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Stuart, No, the arms replaced have not broken. That has lead me to believe that fatigue could be a factor. I also agree with you about the valve siezing in the guide. I don't think it would loosen up right away or at all. During the adj I bring it up on #1 firing and rotate to #6 firing. As I say she runs great though I think the valve train is really noisy. She is getting oil to the rockers though as you know with these low pressure engines it is just a trickel. I'm pretty sure the lifters are pumping up because I don't get any give when pushing down on them after it has been run. I do get some give if it hasn't been run. Am I of correct thinking? | | |
#62235 06/28/2006 3:33 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Glenn,
The only hydraulic lifters I have adjusted were on a V-8. This was always done warm, with the engine running. I am not sure I would adjust a hydraulic in any other way.
Again, my limited experience has been that once a lifter is pumped up, it will stay that way for many moons...it will not collapse or leak down. Maybe a motor will slightly worn parts will leak down.
I think this is a moot point..a distraction. If you have replaced rocker arms and they are now functioning properly, the problem is solved. If you have time to spare, you can brainstorm why it happened, but sometimes the problem gets solved without knowing what caused it.
Stuart | | |
#62236 06/29/2006 1:24 AM | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | GEC52,
Good to hear you got it running. My valve train was still noisy after the adjustment, and I let it run for 5-10 minutes at a higher RPM and the noise disappeared a little at a time until finally it was quiet. Now when I start it, no more clatter.
Correct valve adjustment is very important. The engine should be warmed up which takes about 1/2 hour. The difference between a cold and hot engine can be .005.
I line the ball on the flywheel up with the pointer. Remove distributor cap and rotor should be pointing to #1 plug wire location on the cap, Follow Step 1, then Step 2, then Step 3.
-- or it will be pointing to #6 plug wire-- this is OK.
If it's pointing at #6, start with Step 3, then Step 2,pointing rotor to #1, then Step 1.
Step 1. With engine set at #1, adjust - #1 exhaust & intake, #2 intake, #3 exhaust, #4 intake, #5 exhaust.
Step 2. Then, turn engine one revolution and line up ball with pointer and the rotor should point to #6 plug wire on the cap.
Step 3. With engine set at #6 adjust - #2 exhaust, #3 intake, #4 exhaust, #5 intake, #6 exhaust & intake.
When you start it up if it's noisey let it run for awhile. The noise should go away.
Keep us posted.
-Tom
#62237 06/29/2006 3:09 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Could the rocker shafts be upside down ? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#62238 06/29/2006 4:33 AM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Tim, That's a good question and I have thought about that. The 3 tower holes are on the top and the 6 holes are on the bottom. The shafts have larger holes on top than on the bottom due to the shoulder on the bolts. So, I can't put them on wrong. Thx Tim. | | |
#62239 06/29/2006 4:47 AM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Oilrag, Yup, thats how I do it.However, I haven't been able to quiet them down. How much do you turn them after you have taken the lash out? I have used between 1/4-1 full turn. I can hear the darn clatter over the exhaust across the street. I'm hoping my broken rocker arms have been metal fatigue because the engine hadn't been run for 20+ years. The valves arn't stuck. Plz sent any advise on adjustment. Thx.
Glenn, | | |
#62240 06/29/2006 2:03 PM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Oilrag, I just noticed the bottom of your post states 56, 235. Maybe there is a noise difference due to the fact that you have a full pressure oil system. My 235 is a 51 with low pressure. About as high as it gets is 5-10 psi. 10 when its cold and 5 after heating up. The rockers look well oiled after driving it though. It really makes you wonder how those lifters fill up.
Glenn, | | |
#62241 06/29/2006 3:18 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I am still a little confused on this adjustment idea. If you are dealing with an engine that has been in service, and not just assembled after a rebuild, you adjust hydraulic lifters with the engine running. These old sixes don't spray oil like the V-8s, so the mess factor isn't there.
Timing/crank position isn't a factor..start the rig, let it warm up, pull the valve cover and back each rocker off until it makes noise, then tighten it down until quiet. Then tighten it down the suggested 1/2 or 3/4 turn.
I am not familiar with the low pressure engines that have hydraulics, maybe they operate differently, but a normal engine will have NO lifter noise when adjusted properly. I think this was the point of the power glide/hydraulics combo...civilized, quite, modern!
Stuart | | |
#62242 06/29/2006 4:52 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | No one has taken my suggestion that it may be the lifters themselves. I may be wrong but I still believe the culprit may lie there. Perhaps the wrong lifters, perhaps worn out, maybe something else but it sounds suspicious to me and is certainly worth a look and not too difficult to do. The one hole I see in my logic is the fact that it has always been intakes that have broken (?) If I'm all wet it sure won't be the first time. | | |
#62243 06/29/2006 5:44 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Dave, I have seen your suggestion about the lifters. I haven't figured out how they could be at fault. It seems that if they are collapsed 100%, they are now solid lifters. I don't think a fully collapsed lifter can pump back up if it is adjusted "as a solid". The minimal oil pressure only has to fill the lifter. The little disc valve holds the pressure in the lifter. Under the worst case scenario, maybe the lifter was partially collapsed, adjusted to 1 turn after quiet, then pumped up and bottomed the valve spring, breaking the rocker arm. I don't think that could happen, mechanically speaking. It appears the problem is solved by replacing the broken rocker arms, so one would assume that they were the problem. I have my beach towel handy, I might be all wet too! Stuart | | |
#62244 06/29/2006 6:23 PM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | I guess I really got the group goin on this one. Stuart- the eng has not been in service for the last 25 years. It sat in a barn. I did not replace anything but acouple of lifters and the carb. She started right up and does not burn or knock and runs great. I'm hoping the new arms took care of it. It drove fine yesterday. She is just noisier than hell. I do adjust it with the engine running. I think I might go for another 1/2 turn and see how that affects it. Dave- I have kept your suggestion to look at the lifters in mind. They all appear to be pumped up . There is no noticable difference in the adjustment screw heights. So, I am assuming all are pumped since not all would have collapsed. I just plugged the oiler drain side. That seemed to increase the pressure abit. I am thinking my oil pump is weak. SO, other than the noise I'm happy with the way it is running. I want to thank everyone for their advise. I'll let you if it breaks again. Thx. Glenn, | | |
#62245 06/30/2006 12:25 AM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | bet those 25 yr lifters were stuck,,,were collapsed,,, and pumped up in a combination of all three... so if stuck, some were running solid... some wont pump up... so forth... in your case id think ya want noise untill they break free if they do... try runnin them a little loose and add about a quart of autotransmission fluid to the oil and run it for a while easy, (dont hotrod it) to see if it will clean up and pump up the lifters,,,then try readjusting all of them......the transmission fluid is an old trick for weak lifters....the transmission fuild wont compress as easy as oil...or sumthin like that..... anyway it worked,,,
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#62246 06/30/2006 4:07 AM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Fatweed, I tore down the lifters before I ran the engine. Thats why I replaced two of them. They all worked well on the bench. I might pull them again however just to check them out. Glenn, | | |
#62247 06/30/2006 4:24 AM | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | 1950-53 Passenger W/powerglide push rod is 11 1/4" long. Part # 3835777 Also here is some good information from the 1949-53 Chevrolet shop manual about lifters and adjusting valves. It says there is a certain amount of oil leakage between the plunger and the lifter. It also talks about a small amount of "leakdown" is desiralbe for it eliminates the possibility of a "negative valve lash clearance condition. Note: After the engine has been standing for a considerable length of time, a certain amount of valve lifter noise will occur when the engine is first started due to "leakdown" on those lifters which were holding valves open against spring pressure at the time the engine was stopped. http://chevy.tocmp.com/1949_53shop/06engine/6_007.HTM Valve lifter noise Hard rapping - stuck lifter Moderate rapping - leakdown or clogged air vent in pushrod seat General noise throughout - insufficient oil supply http://chevy.tocmp.com/1949_53shop/06engine/6_010.HTM How to adjust valves. Although it says 1 1/2 after zero, everyone says 1/4. http://chevy.tocmp.com/1949_53shop/06engine/6_012.HTM Here's a good article. http://www.speedprint.com/Deves50/valveadjust.php atomarc, I agree with you about adjusting hydraulic valves on a V-8 with the engine running. That is pretty easy when the adjusting nut isn't bouncing up and down. On these 6's the rocker arm is on a shaft, and the arm is bouncing up and down. It's pretty difficult. It only took me 5 seconds to realize that I can't get a flat head screwdriver in the slot, let alone keep it there and tighten the lock nut.
-Tom
#62248 06/30/2006 5:10 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Oilrag, Great bunch of info and links you provided. I just want to note that I have adjusted many stovebolt valves, many Perkins and Caterpillar valves (solids) and who knows what else. All these had the adjuster located on the end of the rocker arm, just like the Chevy 6. I'm not trying to be a smart arse, but it takes longer than 5 seconds to get the hang of how to do this with the engine running. The wrench gets oily and hot, and the stubby screwdriver hops around, but you get a accurate job and it doesn't take long to get the hang of it. I worked in a auto repair shop as a kid, and this is how they did it...I didn't know any other way. The only downside to this operation is the toll it takes on the feeler gauge. Stuart | | |
#62249 06/30/2006 2:59 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Take this with a grain of salt because the only experience I've had with hydraulic lifters was in my old HD shovelhead. I did find out first hand there that a tiny piece of dirt or crud will keep a lifter from pumping up, resulting in constant lifter clatter. Since the truck sat for so long some crud may have come loose and contaminated your lifters. Just a thought. Another thought (I do that once in a while  ) the hydraulic lifters on my old HD were directional, meaning that the oil hole in the lifter had to be on the same side as the oil passageway in the engine. Many times I helped "fix" noisy lifters by turning them around after an unknowing person put his lifter(s) in backward.
#62250 06/30/2006 7:34 PM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Tiny, You make good points. The more I read and adjust the more I'm thinking it is lifter noise and not valve clatter. Oilrag great sites. Thx a bunch.
Glenn, | | |
#62251 07/07/2006 6:11 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | |
#62252 07/08/2006 4:44 AM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Chuckthetruck, It is so cool to see these old trucks brought back to life.
Glenn, | | |
