| | | Forums66 Topics128,271 Posts1,058,412 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | | Doms48 Unregistered | | Doms48 Unregistered | I'm wondering if anyone has ever tried fabricating a vintage looking camper box onto a stock 1.5 or 2 ton Advance Design Cab and Chassis? I have not seen anything that really looked attractive in my searches. They all seemed amateurish and ugly (along with rusty and rotten plywood) or were old milk/bread delivery vans, not real standard trucks.
I was thinking it would be cool to custom build a self contained "boondocking" unit on a short wheelbase 1.5 ton. Generator, atmospheric watermaker, toilet, kitchenette,propane furnace/stove etc etc. Most parts could be recycled from old scrapper camper trailers. Under framework in steel, rest in wood and insulated. Sheath it in flatstock roofing steel. Roll out awnings... trailer hitch to tow your boat or 4 wheeler/skidoo/whatever.
It would have to be somewhat streamlined to match the period (40's/50's)
Any pictures online? edit: On further thought, I suppose you could just use the truck to pull a vintage trailer like a semi unit or bumper pull leaving the truck free to carry stuff and serve as transportation...
| | | | | Joined: Feb 2007 Posts: 195 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 195 | There is a beautiful 1945 school bus converted to a camper in the Gallery.
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
| | | | | Joined: Nov 2000 Posts: 1,975 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,975 | A couple of years ago I downloaded this picture of an Advance Design 1-ton I guess with a frame mounted camper here but this may not be what you have in mind.
Professional Novice
| | | | | | Doms48 Unregistered | | Doms48 Unregistered | Frank50, That is cool! Not quite "Art Deco" looking, but still looks like a nice camping rig. | | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | I'd like to build a camper that sits on my flat bed, which comes off easily when I don't need it. Chris | | | | | Joined: Sep 2007 Posts: 5 New Guy | | New Guy Joined: Sep 2007 Posts: 5 | i am giving thought to moding an old airstream onto my '42.
alton
| | | | | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | Doms Go here http://home.comcast.net/~robmorg/oldmh/oldmh.htm It is a buss but it's Art Deco. | | | | | Joined: Aug 2009 Posts: 184 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 184 | I cant say I have ever seen any streamlined campers placed onto trucks. They are mostly boxy looking things.
I think it would be hard to use an Airstream trailer to make into a removable camper without it looking exactly like that is what you did. I would do some computer editing to combine a picture of your airstream with your '42. It doesn't take much skill to use Microsoft paint, although the quality you can achieve is limited as well. If you can't do that take a couple of pictures and cut-and-paste with a real photo. Make sure your pictures are taken from the same angle and from the same distance in either case.
Whatever you do if you plan well you will be more likely to be happy with the way it turns out. Many people do not plan enough and just start putting things together.
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
| | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 |
| | | | | Joined: May 2009 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 99 | I know this thread is almost a year old, but...
Streamline, I think, made a camper shell. They were a similar looking aircraft aluminum competitor of Airstream.
It would look great on an old bolt. Rounded corners, etc. There are some creative mods to vintage campers out there on the net. I think with sheet metal skills a nice camper could be fab'ed out of one of those old Airstreams.
Dave.
Dave.
What's the last thing a red neck says, "Hey guys watch this." What's the last thing a redneck hears, "Go ahead Bubba, you can do it."
Build plan: 65 Chevy one ton, 5.9L Cummins HO, NV5600 six speed, 2wd 1972-1987 IFS disk front, frame off restore/mod, custom dump/flat bed, Alcoa rims, Dana 70 3.73:1 duals drum rear, plush interior, Guards red with Marine Corps decals. Donor is retired 2002 Ram 2500, 194K miles.
