1 members (Hotrod Lincoln), 61 guests, and 2 robots.
Topics128,049
Posts1,055,740
#621230 02/18/2010 8:43 PM
Can someone recommend a good brand name paint to put on the exterior of brake drums? My front ones are especially rusty and need some kind of protection from the elements and to slow down their deterioration. I'm assuming that it should be a high temp primer and top coat rated for at least 500 degrees. Right? Or does it need a higher temp rating?
"Lucille" ..... Proud Member of the "Southern Stovebolts"
David Wolff
1946 Chevy 1/2-ton
Are you planning on running the truck in NASCAR? Spray bomb rustoleum or engine enamel should be adequate.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Lucille #621269 02/18/2010 11:43 PM
Can't say from experience but I would think POR-15 would be up to the job.
cshamel #621276 02/19/2010 12:20 AM
Apprentice
Apprentice
I've always had good results with either Rustoleum/Tremclad. I always throw them into the BBQ after 24 hrs of drying & then touch up any peeled spots. Be careful of the smoke & don't cook dinner in the BBQ the same nite.
... a good black enamel will do well. I used some high temp engine paint I happened to have on the shelf and its held up well.
EDIT: David, it was good to see you the other day. Wish we could have had more time.... so we could have ate more hot dogs and Pepsi smile
I used the black paint meant for repainting BBQ grills . It definitely is a high temp paint and has held fine . Of course , prepping the drums for paint is essential .
" The heart of the wise inclines to the right , but the heart of the fool to the left " - Ecclesiastes 10:2
Check out some of the caliper painting kits out there and see what you think. Duplicolor, etc. Plenty of heat resistance and they hold up well.
1951 restoration on website
http://www.hanklong.com
