1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61950 06/20/2006 2:42 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Has anyone ever put one of these on their 235 or in-line 6? They are on sale for $24 at Kraigen. Does it matter which end you connect from the manifold to muffler pipe? Raptor | | |
#61951 06/20/2006 8:06 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Oh really? I have a 2-1/4 with adaptors to make it a 2" My truck already has a 2 inch exhaust pipe. What kind of problems would result? | | |
#61952 06/20/2006 9:59 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Billy...I have to agree with AD-52. Without backpressure no engine runs as well as it will with some. If your running a split or dual exhaust manifold keep your exhaust to 1.75 into the muffler. Dual 1.75 or 2" outlets work OK on a one-in two-out muffler. IMO 2.25" is quite large for most Chevy inlines. Why don't you check out Flowmaster and/or Gibson websites and see what they have to say about it.
Bigger isn't always better. | | |
#61953 06/20/2006 10:21 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | I have a stock single manifold with one out. With 2" pipe | | |
#61954 06/20/2006 10:27 PM | Joined: Oct 2005 Posts: 4,250 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,250 | ?????
Then why do folks put headers on V-8's to get more "scavenging"? Is there back pressure on top fuelers with the straight pipes?? You've peaked my curiousity. Is it a difference between a high horsepower motor and a low horsepower inliner. Apple and oranges? Would an inliner run worse with a straight pipe and no muffler ( and louder?) I know big diesels use the blower and turbo to blow out the burnt mixture and to pack in a high compression mix for combustion. | | |
#61955 06/20/2006 10:38 PM | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | MN SMITH I agree with you, The only exception is 2 cycle engines cuz they actuallly suckback in the exhaust pipe. tuning the pipe is critical I found after racing sleds at different altitudes. | | |
#61956 06/20/2006 11:16 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | With the straight pipe the engine ran strong and sounded very good. When I put on the Muffler is ran worse and not as strong. | | |
#61957 06/21/2006 12:22 AM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | This is a little long on explanation and will not use words like "pulse" or "reversion". Do NOT mean to insinuate any contributers are not sharp but as a professor once told his class--if I use words or examples some don't understand then both persons time has been wasted. The exhaust should be sized so the "ball" of exhaust traveling out the pipe will fit the inside of the pipe like the piston in an old time suction gun. This leaves an suction behind the ball that helps pull any unburned gasses out of the cylinder AND pulls a new fuel/air charge into the cylinder when the intake valve valve starts to open. It's called the "scavaging" effect. When the pipe is too large the ball fits too loose and has no suction. Of course, as usual, there are exceptions, such as a very high rpm engine where there are many more pulses(balls) so that even though there is less suction to each one there are so many more it results in a net gain. Also on super/turbo charged engines the incoming charge is under boost(pressure) so a very low restriction exhaust is desired. I can hear the guys with a background in fluid dynamics laughing their hineys off at this explanation but I hope it does show why proper sizing on the exhaust does have an effect.
Evan
#61958 06/21/2006 12:30 AM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | I'm running split headers on my 292 with Cherry Bomb glasspacks and 2" pipes from the header bell to the mufflers and then the same size out the sides. Runs fine. Much better than with the little bitty strangulation pipe that was stock on it.
I agree about 2-strokes (and rotary motors) needing backpressure, but on conventional 4-stroke, normally aspirated motors, I think it's pretty much academic until you get to things like tuned exhaust with equal length tubes and measuring flow rates to evaluate for maximum efficiency, especially with valve timing that has a lot of overlap where scavenging becomes critical. I'm sure the F1 guys have all sorts of computer models to design this, but on our trucks, I think it's a little over the top.
Granted, I wouldn't put 4" duals on my 292, but as long as I have a relatively mild motor, anywhere from 1.75 to 2.5 should function about the same.
Now if anyone has done extensive research or knows of any that refutes this, I'd love to investigate it. | | |
#61959 06/21/2006 1:20 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That muffler sounds pretty good to me, no gurgly noises like a Flowmaster (they sound like an out of tune Quadrajunk to me). I have 2" duals on my 235, all stainless, with a pair of CJ 7 mufflers and don't have any power problems. But I don't think that you would want want to run any larger than that on a 6 or even a mild v-8. Wild smallblock or big block maybe a larger pipe would be ok. If you want to make a big pipe look put a tip on the tailpipe the size you want. By the way, a guy I work with who's int the import thing put a low restriction , no muffler, fart can exhaust on his '91 Accord, now he has a burnt valve on #3 and the engine has no power. Didn't have this problem until he did the exhaust.
Bill Burmeister | | |
#61960 06/21/2006 1:51 AM | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | What I did with my '53 6500 was to weld end caps on a piece of 4 inch box tube about three foot long for a collector.I rubber mounted it(for vibration insulation)side to side behind the cab.I then cut two holes for the two inch ID 304 stainless stacks and welded in three bolt flanges for each(with stainless acorn nuts).I cut an inlet on the bottom again with a three bolt flange.I added two rain caps on the top and it sounds so sweet especially pulling under load.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#61961 06/21/2006 5:30 AM | Joined: Jun 2006 Posts: 6 Junior Member | | Junior Member Joined: Jun 2006 Posts: 6 | I just installed two Raptor mufflers about a month ago on my 51 with a 235 engine. I am pretty happy with them, sound and performance. Like someone said earlier, 2 inches is a little big for the engine, but with the amount of power its making, I think the difference is going to be minimal. They are a great price though. Figured anything was better than the previous owners system. One rusted out glasspack, cuts out mid chasis, and one huge modern muffler with a tailpipe exiting in the back. I was running straight pipes, awesome idle, full throttle was embarassing, making all kinds of noise, and hardly moving. | | |
#61962 06/21/2006 6:37 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | MNSmith - I thought this would require a lot more explanation than I can offer so I was hoping an expert might jump in. About your question as to a long straight pipe and no muffler I used to see this years ago on school buses w/ inline sixes and they sounded great. It wasn't too loud however or uncomfortable. So I guess that works OK too but I believe the length of the pipe more or less acts somewhat like a muffler. But yes I do think it's apples and oranges on a high HP engine vs an old straight six. I don't pretend to understand all of this and it's why I suggest we ask the experts at Gibson or Flowmaster or others. I'm sure they can explain it all properly in terms most could understand. I hope this string stays alive for a while as it seems to be of interest to many. | | |
#61963 06/21/2006 9:40 PM | Joined: Oct 2005 Posts: 4,250 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,250 | I think coilover did a great job of making sense of it all. I'm putting a small block TPI in my 'burb, so I have been looking for headers. My favorite maker, which I have used before, is Sanderson Headers. Their web site has some good tech info, basically the same stuff coilover was talking about. http://www.sandersonheaders.com/tech_get_technical.php Also, some neat stuff there regarding changing pipe sizes midstream ( creates turbulance and backpressure.) http://www.sandersonheaders.com/tech_complete_performance_exhaust.php | | |
#61964 06/21/2006 10:19 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | If I read that correctly then I can run my straight pipe without a muffler. At least for a little while. What's the worst that can happen besides being loud and a possible ticket.
So does anyone want to buy my Raptor muffler for $10.00 only been ran for 10 min. I suppose I have to buy a new one that has 2" in and out lets. | | |
#61965 06/21/2006 10:45 PM | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | MNSmith, good Sanderson sites. I'm running a '56 235, 848 head, Fentons, 2" pipes to 2-26" glasspacks and I'm ready to place an 'x-pipe' in the mix. I've been thinking I'd like to try the 'X' with NO mufflers, anybody ever tried this?
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
