1 members (Rusty Heaps),
114
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | The tag behind the distribtior is stamped JAD447433 Trying to find out what i have year ect what it came in ?????
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The JA prefix on an engine serial number was supposedly used in 1951 on automobile engines. The D is a code for the combination of manufacturing plant and model.Most likely the engine has a valve cover with two bolts n the top? If any of the above is not correct, we can trust that someone will post corrections (please). _____ Here's a wild guess on the D in JAD - option 313 (Powerglide transmission) from the Flint plant. One way to tell if this is a good guess would be to see if it has hydraulic lifters.
Last edited by tclederman; 02/13/2010 1:54 PM. Reason: later guess about the D in PAD
| | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | Tim is correct. The "D" in JAD designates the automatic transmission option in 51' manufactured at the Flint plant. This below resource says option 317. So, JAD decodes as a 51' 235 engine originally built for the powerglide option and available in any of the "Deluxe" passenger 2100 models listed here: http://chevy.oldcarmanualproject.com/chevyresto/51042.htmA pictorial of the models is here: http://www.tocmp.com/brochures/Chev/1951/pages/51chevy2_jpg.htm
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | is this a full oiller motor
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | No, the high-pressure lubrication system first was available in 1953 235 engines in Powerglide-equipped cars.
