1 members (stoveboltgator), 218 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#619488 02/13/2010 1:18 PM
The tag behind the distribtior is stamped JAD447433 Trying to find out what i have year ect what it came in ?????
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
apart hillbilly #619494 02/13/2010 1:48 PM
The JA prefix on an engine serial number was supposedly used in 1951 on automobile engines.
The D is a code for the combination of manufacturing plant and model.
Most likely the engine has a valve cover with two bolts n the top?
If any of the above is not correct, we can trust that someone will post corrections (please).
_____
Here's a wild guess on the D in JAD - option 313 (Powerglide transmission) from the Flint plant. One way to tell if this is a good guess would be to see if it has hydraulic lifters.
Last edited by tclederman; 02/13/2010 1:54 PM. Reason: later guess about the D in PAD
tclederman #619663 02/13/2010 11:53 PM
Tim is correct. The "D" in JAD designates the automatic transmission option in 51' manufactured at the Flint plant. This below resource says option 317. So, JAD decodes as a 51' 235 engine originally built for the powerglide option and available in any of the "Deluxe" passenger 2100 models listed here:
http://chevy.oldcarmanualproject.com/chevyresto/51042.htm
A pictorial of the models is here:
http://www.tocmp.com/brochures/Chev/1951/pages/51chevy2_jpg.htm
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
randyl #619692 02/14/2010 2:24 AM
is this a full oiller motor
AND A MARINE
apart hillbilly #619707 02/14/2010 2:57 AM
No, the high-pressure lubrication system first was available in 1953 235 engines in Powerglide-equipped cars.
