0 members (),
137
0
Mod | | | Forums66 Topics128,102 Posts1,056,184 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Hey, it's the man of many questions again, ha ha! Ok, this should be a simple one....I replaced my speedometer cable because the old one twisted and broke at the transmission. The new one was a pice of cake to install, and it works...kind of. It buzzes and bounces all over the place like the old one did before it broke. Did I maybe miss a step when I installed it? Maybe my speedometer itself is screwey? | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | maybe it needs some lube. but don't wait too long or it may break the needle. | | | | | Joined: Mar 2009 Posts: 169 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 169 | you could check and see if the odometer numbers are turning,sometimes they get stuck.... | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | Is it a reproduction speedo cable? I put a repro in, and there is supposed to be a little crimped on ferrul at the speedo-end of the cable, that keeps the cable in the sheath, rather than slipping down into the trans. It's possible yours is slipping out of the end of the speedo head and just catching it erratically. Your speedo could also be about to die. Mine did that right before it croaked. I ended up finding an original speedo cable set-up, washed it in the parts washer, and lubed the cable with white lithium grease. It's going back in the next two days for a 1,000 road trip to Missouri. It'll be nice to know what I'm getting for gas mileage, and how fast I'm going!
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I am not sure about your 61 but on some earlier models like my 52 the needle will bounce around a bit and act crazy. If you catch it in time a good lube will work wonders. The earlier ones had a "wick" to lube them and they dry out over the years. Before you do anything be sure to "measure twice, cut once". Let us know what you find out. | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Well, I took it out of the speedo guage the other day, it has a plastic end on it which stops it from falling back down towards the trans. I lubed it with some all purpose grease and put it back in. Was ok for a little bit but is now starting to make some noise and bounce around again. Maybe the speedometer is about to kick the bucket. | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | What you need to do is pull the instrument panel, remove the speedometer and lube the gears on that. If the gears are not damaged yet then it may be okay yet. I would say the issue is more with the speedometer than the cable.
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
| | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | | | | | | Joined: Oct 2009 Posts: 19 New Guy | | New Guy Joined: Oct 2009 Posts: 19 | I thought I would add my problem here. MY speedo works fine unless it is below freezing. This morning we had a wind chill of 8 and the speedo was really noisy and bouncing around like crazy, after about a mile it cleared up and worked fine. Any thoughts on what to do? I don't want it to break.
Thanks! | | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | My dad always used parifin(sp?)wax used in canning,it won't freeze. | | | | | Joined: Oct 2009 Posts: 19 New Guy | | New Guy Joined: Oct 2009 Posts: 19 | Thanks todjob, but pardon my ignorance... where do I apply the parafin? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Unscrew the speedo cable from the back of the dash cluster and drip 3-in-1 oil in the cup. Do this for several minutes, to allow the oil to flow down the cable, as far as possible. Over time, the cable gets dirt in it, causing it to bind when the temp is real low. | | | | | Joined: Oct 2009 Posts: 19 New Guy | | New Guy Joined: Oct 2009 Posts: 19 | Thanks! We'll do. Appreciate the help. | | |
