5 members (51sub, Stovebolt48, carbking, Wayne67vert, 1 invisible), 51 guests, and 1 robot.
Topics128,041
Posts1,055,593
#618247 02/09/2010 5:47 AM
I have a 56 gmc with pontiac engine and a 12 volt system which has a postive groung. When charging the battery do i still go positive to positive with charger to battery? seems logical thanks for help tom headscratch
56dump #618251 02/09/2010 5:55 AM
Yep!
Yup that is how I have my battery maintainer hooked up on my "positive ground" 67 Triumph motocycle....works just fine.
Tim
1952 Chevy Shortbed
Photos in Photobucket
Yes, Just make it a habit to check the water/acid level before hooking up battery chargers.
Are you referring to an original GMC 1956 V-8 (maybe a 316 or 324)?
I think that all 12v GMC electrical system were negative ground.
Through 1955, all GMC 6V 6-cylinder electrical systems were positive ground. In 1955, GMC 8-cylinder electrical systems were 12v negative ground (except V-8s in school buses were still 6v).
Chevrolet changed to 12v for all engines in the 1955-2nd series trucks.
Seems to me the 1956 GMCs were negative ground, as I think all GM vehicles were by that time. But I don't have any specs on the GMCs.
Harvester
On passenger cars, all the manufacturers standardized their electrical systems at 12 volt negative ground in 1957. There were a few 12V + ground systems in 56, notably Ford, Nash, and Packard, not sure about GMC. Commercial trucks like Freightliner kept the positive ground up through the mid-1960's with the idea it made for more reliable grounding and less galvanic corrosion, especially where aluminum and steel were used together.
As Harvester posted, all GMC trucks went to 12v negative ground for all engines in 1956 ( See page 16 ).
If there's a reference to ground polarity on page 16, I haven't found it yet.
Yeah, I don't see it either, and what difference would that make anyhow? The original post says it's pos. ground, and he wanted to know how to hook up a charger. I believe him, it's pos. ground.
Even if the literature of the day says ALL units converted to neg. ground on such-and-such a date, from what I've seen, there always are exceptions to the rule.
