5 members (Forty9, Hanks custodian, 78buckshot, Pre '68 Dave, 55shaker), 129 guests, and 8 robots.
Topics128,077
Posts1,056,031
Members48,433
#61742 06/14/2006 10:42 PM
My new 261 is finaly ready assembled. Tomorrow I go and hulk it in the 41 grin
261 -1
261 - 2
261 - 3
261 - 4
261 - 5
#61743 06/14/2006 11:48 PM
Way cool. What is that gizmo behind the alternator?
40 Chevy 1/2 ton
#61744 06/14/2006 11:48 PM
That's pretty. One question, did you reduce the size of the oil lines coming out of the block, or is it just hard to see they're 1/2 fittings?
If you did reduce them, why? Courious is all.
I'll bet it runs as good as it looks. Good work.
#61745 06/14/2006 11:49 PM
That is a thing of beauty! Congratulations!
I love the aircleaner, what is it off of and where did you get it?
The vette split manifold and polished offy dual intake look great!
Nice touch with the machine turning on the acorn nut valve cover!
The PCV set up coming off a later draft tube wth a glass bowl fuel filter inline (to trap condensation I assume???) is beautiful!
What carbs and tranny are those?
#61746 06/15/2006 1:18 AM
Whew Momma, get the kids in the house. Theirs a monster out there. That looks awsome. wink
"All right, they're on our left, they're on our right, they're in front of
us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC
#61747 06/15/2006 1:33 AM
That's beautiful. My guess is that it is a pre-'58 261 (smaller oil filter lines/holes).
Please answer the questiona above, especially tell us about the air cleaner and carbs that you are using.
Is that an oil filter behind the alternator?
Electric fuel pump?
Very nice. Makes want to reconsider selling my 261 and putting it in my Suburban.
#61748 06/15/2006 10:15 AM
Here is a closer picture of the oil lines:
Oil lines
It is a Frantz toilet paper filter.
The intake line is a bit smaller (6 mm) than the outlet (8mm). It is a bypass filter anyways, so I reduced the intake line to maintain oil pressure.
The Aircleaner is a Hillborn style scoop out of an ebay speed shop. It has two round standard paper elements inside.
@NM51 You have eagle eyes. I cut the draft tube away and fitted the PCV line. The condensator glas is a modified fuel filter bowl. I will fill it with sileca gel to gain some economy.
Carbs are progressive Holley/Webers, tranny is a 1959 maunal 3 speed with overdrive.
Since i want to keep everything 6 volts I use a Ford 6V overdrive solenoid.
Yes, electric fuel pump. Block off plate is of a big block grin
Here I got the idea of the PCV condensator glas:
http://www.condensator.com/
or search for "PCV jar" in google.
Here is the Frantz Filter page:
http://www.wefilterit.com/
Frank
#61749 06/15/2006 11:54 AM
Wow! That's the first Frantz filter I've seen installed in about 30 years.
Great looking motor. I can hardly wait to hear the reports of how it sounds and drives.
#61750 06/15/2006 3:13 PM
V
V Offline
Looks great !
Those PCV lines look way too skinny to properly vent the crancase tho' .'
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#61751 06/15/2006 6:13 PM
makes me wanna get out to the garage and finish my 261...oh! i forgot, i'm out of money!!!
#61752 06/17/2006 12:28 AM
Probably a dumb question. But where does the line go from the intake manifold?
I have the same on my offy intake I'm not sure what that is for? Vaccum?
#61753 06/17/2006 12:32 AM
It's the vacuum port that runs the wipers and the Hydro-Vac(if eqyipped).
Bill Burmeister
#61754 06/17/2006 7:48 PM
Exterior looks nice. What about the guts? Bored block? What'd you do to the head?
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#61755 06/17/2006 8:20 PM
Hey that looks great!!You can't beat a 261 for low end power.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#61756 06/18/2006 10:42 PM
Mugsy here are the guts:
bore 0.06 over, head and block milled (head is a 848) compression 9.2:1.
Langdons Bulldog cam, solid lifters, Ford (I confess it) valve stem seals (umbrella type).
Still thinking about the exhaust. As you guys can see it has a corvette style split exhaust header.
Right now I have two 2.1/4 inch pipes all the way to the back with 2 flowmasters.
I belive that the pipe diameter is to much and I loose low end power. What diameter was the original corvette Inline 6 pipes?
Thanks, Frank
#61757 06/19/2006 9:05 PM
Looking good Frank! Can't wait to get my 261 completed as well and back in the truck! Getting ready to work the fuel, vacuum and intake manifold hot water lines.
http://community.webshots.com/user/geezer
Country Roads, West (By God) Virginia
#61758 06/20/2006 12:42 AM
do you have the specs on the bulldog cam?
#61759 06/20/2006 2:31 PM
Anonymous
Unregistered
Anonymous
Unregistered
that's a sweet motor but you forgot to tell us how much you want for it. wink
http://community.webshots.com/mypho...mp;albumID=551424330&security=ekZMUw
