7 members (TUTS 59, homer52, Otto Skorzeny, Youngin' Tut 59, dt235sd, 2 invisible), 122 guests, and 1 robot.
Topics128,052
Posts1,055,727
#6174 01/17/2005 5:54 AM
Junior Member
Junior Member
During the conversion from a 235 to a 283 I have discovered that I have no throttle linkage. I bought the truck in pieces a nd have a couple of linkages that I believe where the rigt ones for the 235. I have tried them every way possible and believe that there are parts missing. I don't think they would work anyway. Can I get a linkage out of a later model and if so what years. The motor is a 1965 and the truck is a 1958. I have tried a couple speed shops and they look at me like I'm crazy. I know others have done this. What can I do or where can I get one?
#6175 01/17/2005 7:30 AM
there's a V8 linkage available from the repro suppliers for the TF trucks - exactly like OEM that's pictured in the assembly manual - don't remember which place I got mine [Carter?] but it works perfect on any small block
#6176 01/17/2005 8:30 PM
Junior Member
Junior Member
Bill, I am not familiar with the term TF trucks? Also is Carter a supplier of parts as I have not heard of them and am eager to get a replacement.
Kurt
#6177 01/17/2005 8:49 PM
Kurt,
There's more to the 'bolt than the discussion boards. Follow the link to Links on the top bar and you will find all kinds of vendors (including Jim Carter's).
Good luck.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
#6178 01/18/2005 4:54 AM
I've made a mid 70's accelerator pedal and cable set-up work on my V-8 equipped 48 1 1/2 ton truck. Fairly simple way to go,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#6179 01/18/2005 6:06 AM
Another very cheap alternative to get a cable linkage is to go the wrecking yards and look at just about any of the 60-80's Datsun/Nissan pickups. The throttle pedal is held to the firewall with one or two bolts, and the cable attaches to the firewall right above it, and the other ned of the cable bracket is on the carb mounting bolt, and will require some slight modification to attach to the V-8, but should work pretty well, and will look clean for a very inexpensive cast.
Good Luck, Garry K
Garry K in Pac Nor West
1948 Chevy PU 235 SM420 4 spd
1932 **** B pu
1964 Datsun 4x4 with SBC, SM465 4spd and Rockwell xfer Dana 44Fr and 12 Bolt Rr.
#6180 01/18/2005 10:27 PM
Junior Member
Junior Member
Thanks to all. I have ordered a replacement from Carter's. Should be in next week. Thanks for all the help. Hope I can be of assistance for one of you all someday.
Kurt
#6181 01/19/2005 5:05 AM
Kurt - "TF" is what ya got - 55 2nd to 59 is the "Task Force era" [Chevys sales hype] - the 'apache' part started in 58 and applied to any light truck [31,32,36,38 series] whereas the 'mid size' 40 and 60 series were called Vikings, and the heavy weights [21,000 gvw +] were called Spartans
I have guys ask sometimes "that's an apache, isn't it?" when I'm drivin the 57, as if that makes it deelux, or not a chevy grin "I say no, it's a pickup truck!" grin
#6182 01/19/2005 6:15 PM
Junior Member
Junior Member
Thanks Bill. I was not aware that is what TF meant. Always looking for info like that.
Kurt
