2 members (JeffA, Mike B), 167 guests, and 2 robots.
Topics128,162
Posts1,056,938
Members48,458
Finaly after a very long time and the ups and downs of 5 young ones and the wife, I'm on my way to assembly. Through the wonderful blessing God gave I can move forward with the PG-ADAMS CHASSIS I had to hold off ordering. Though I wanted to follow the similar path as Grigg with diesel power, I just cant get it done. But a very stout 350 and an SM-465 trans and newer axles with better gears makes the idea in the pic below attainable. The chassis will not be the original (STRONGER) and the suspension will be a little different with heavy duty airbags doing the load lifting, I still consisder it "one saved from the death of rust". I'm waiting on the email from PG-ADAMS with quote and dimensions tommorow. Tell me what you think of the photo playing Ive done with the image below. My actual truck is seen in my signature.
http://i226.photobucket.com/albums/dd15/46cabover/thenewtruck.jpg
1946 Chevy 1.5-Ton Flatbed
Photobucket
Old Big Trucks are built to last.
Hey,
Have you gotten any clue what kind of a job it's going to be to put that 350 in and auto. I am trying to do the same.
Thanks, Jack
I like that a lot! Should be a neat, safe toy when it gets rolling and able to go a bit faster too.
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
Thanks Tomcoe, I'm finaly moveing forward again yahoo
Photobucket
Install will be a breeze jack02 and hopefully the Novak hydraulic clutch setup will be a success. thumbs_up
Photobucket
I always had good luck with the early 60's Chevy truck hydraulic system;they're pretty near bulletproof,but if something does fail parts are readily available. They're adaptable,too-you can install 'em on nearly anything.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
Have you given any thought to buying a three axle truck and moving the cab and fenders on to that chassis?
Something like maybe a Chevy Top Kick then you could even keep it all Chevrolet
thumbs_up
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Valuable information (speed 6351) I did not know that. thumbs_up
Photobucket
I gave it a realy brief thought because I figured everything would be to large for the small body: Big frame and more. Maybe the top kick I have in mind is incorrect.
I remember driveing the old kodiak dump trucks working for the city and some had tandems but If I'm seeing the wrong image help me out because this will not be the only truck that I build and your idea sound nice. headscratch
Photobucket
