4 members (Chip O, Otto Skorzeny, Wayne67vert, fonz8261), 51 guests, and 4 robots.
Topics128,077
Posts1,056,016
Members48,433
Hello Everyone
I try to identify the year and size of my Canadian c15 truck engine.
The engine looks about the same as the usual stovebolt ones
I searched already By the Tech Tips, the Onliners and the Forums but got no results so far.
The Nr.on the pad behind the distributor is: XR 3696705.
I should appreciate any information.
Thank you
Jianis
http://s875.photobucket.com/albums/ab317/Jianis/Stovebolt/
http://s875.photobucket.com/albums/ab317/Jianis/Canadian%20C15%20Truck/
Hello Jianis.
Welcome to Stovebolt.com
Can you add a few photos of your engine to you photobuckets album? This might help us help you.
Hello again
Here is a link to some engine photos from my C15 truck
That’s all the engine photos I have for now as the truck is parked some 2500 miles away under a carob tree in Crete.
Jianis
Has this truck been underwater? Normally I don't see that much scale in an engine.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
We always make boat anchor jokes about engines but I think that one has already been there done that.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
H Online: Content
Do you have an idea of the year of the truck? The tall side cover would indicate it's either a 216 or an early 235. They're both splash-oiler Babbit-rod engines, and that one looks too far gone to restore. The 216's date back to 1937 or so, through 1952 or 53, and the 235 started out in 1941, I believe, and also went to 52 or 53 before it got upgraded to full-pressure oiling and a different cylinder head/short side cover. According to a couple of websites I've found, it's supposed to have a 216 engine:
http://www.autogallery.org.ru/m/cmp15.htm
Dave
The truck was left outside for some 35 years with no engine cover and the roof hatch open.
53 monster
For 99% it should be used as an anchor.The main idea is finding out the age and size of the engine.
You are right about the size of the engine the c15 was using,it was a 216.
So far I also know that this truck should be made between late 42 to mid 44 only try to get a more accurate date.
I am familiar with the later 216 engines but never seen this shape before
Thank you all.
Jianis
H Online: Content
Here's a 216 in a little more complete condition:
http://cgi.ebay.com/ebaymotors/1947...ck_Parts_Accessories?hash=item4ced704b6d
Notice that the sheet-metal side cover goes all the way up the side of the engine to the valve cover. All the 216's I'm aware of with the possible exception of the 1953 model engines had the tall side cover. 235 splash-oil engines from 1941 to 52 had the same configuration. Later model engines had a side cover that did not extend over the side of the cylinder head.
