| | | Forums66 Topics128,035 Posts1,055,570 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 11 New Guy | | New Guy Joined: Apr 2004 Posts: 11 | I have a 350 olds in my truck and had just installed a new starter . The problem is when I turned the ignition on and hit the starter button it would engage and turn slowly . I let off the starter button and it was still slowly turning over . Then I turned off the ignition and it still turned over slowly . I had to unhook the battery to stop it cranking . I was wondering, if the starter needs shimming ? If it was too tight would it keep the starter gear engaged and keep current flowing ? If everything's coming your way , your in the wrong lane... 1958 GMC Shorty | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | It sounds like it needs to be shimed a repair manual for that engine will spell out the best way to do it.
Pete | | | | | Joined: Apr 2004 Posts: 11 New Guy | | New Guy Joined: Apr 2004 Posts: 11 | I bench tested the new starter . I grounded the body and flashed the positive to the "S" terminal & the heavier main terminal . The solenoid works but the starter doesn't crank . Any ideas ? it also has a "R" terminal but my truck only has a positive to the starter and one wire from solenoid to starter button . If everything's coming your way , your in the wrong lane... 1958 GMC Shorty | | | | | Joined: Apr 2004 Posts: 11 New Guy | | New Guy Joined: Apr 2004 Posts: 11 | Problem solved , I had to hook the heavy + terminal , then flash the S . Now to deal with the shimming . Thanks for your reply Pete52 . If everything's coming your way , your in the wrong lane... 1958 GMC Shorty | | |
