6 members (Hotrod Lincoln, Peggy M, Otto Skorzeny, DadsFirstPickup, dinosoar, Robert Crandall), 120 guests, and 2 robots.
Topics128,127
Posts1,056,675
Members48,450
#612790 01/23/2010 11:22 PM
I am just woundering what you old pros think of coating the whole inside and outside of the cab with por 15 just to make sure all the pin holes are sealed up along with all the nooks and crany's so they don't come back to haunt you afer the paint job is done. Thx:)
...don't know about using in body work but it is some tuff stuff.
I know two guys locally that swear they only painted a gas tank with many pin holes in it and after the stuff dried they put the tank on and have driven it for years without any leaks. I suppose it would work with the body work if since you would sand everything off but whats in the pin holes?
I'm sure you'll get more educated input from body men.
I understand that POR-15 is an encapsulating paint,but would it not make more sense to deal with the pinholes,then overcoat with POR?
As far as painting the outside of the cab,i'm not sure how that would work with your final paint job.
Standard auto paint/lacquer would be air tight any way,so assuming you painted the inside with POR and then the outside with Auto paint,would that not have the same effect?
More pix on Flickr.
I've used POR15 on the inside floor and underside of my cab and the underside of my fenders. It isn't really a good base for a top quality paint job. I only used it where rust is a serious problem and where it is out of sight. It is extremely hard to sand and it doesn't level as well as you think. I would recommend that you only use it in areas that are out of sight.
Thx for the input on por 15 as far as the pinholes are concerned
I was only thinking of using the por 15 as somewhat of an insurance because even as carefull as I am trying to be with replaceing all the necessary metal I worried about that one little hole that got missed and will end up spoiling the paint job.
Any place that I'm unsure of, or were I've welded in a patch. I use a product called all-metal on the inside and out before I do the final mudding.
