4 members (gswbbc, rfs56trk, HandyAndy, 1 invisible), 45 guests, and 3 robots.
Topics128,040
Posts1,055,478
Members48,424
#61328 06/05/2006 3:48 AM
Junior Member
Junior Member
I need to buy a new master cyl for my 52 3/4 3600 pickup. My catalog lists one for double duty and except double duty. How can I tell which one it is?
Thanks for any help.
Mike
#61329 06/05/2006 4:35 AM
you want the one for "all except double duti" [that's a step van]
#61330 06/06/2006 12:12 AM
I
I Offline
I put one in my 52 this winter. I'll have to go back and see what number I used. I know it took the same one as my 47 2 ton truck used. I'll let you know tomorrow what it was.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#61331 06/06/2006 12:25 AM
Since you've got to switch it anyhow, why not upgrade to a dual master- CPP has 'em with the bracket. That way if your front brakes fail you've still got the back ones (and the e-brake).
#61332 06/06/2006 12:37 AM
I
I Offline
Does that unit fit in the stock location, with out modifing. I've looked at upgrading my systems but it seems like you have to change a bunch of things, like the pedals, and location. I'd like to figure out how to install a dual using the Hydro-Vac.
Jeff
1953 3/4-ton
#61333 06/06/2006 3:58 AM
You would have to use a normal booster on a dual res. master, which I've done on my V-8 48. It's mounted under the floor in the stock location using the orignal clutch/brake pedals' bell crank. Now would be the time to do it on yours since the body is off. Let me know if you want to persue this further. I'll let you know what master I used and what you need to look for in a booster,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
