0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | I'm putting my springs back together. Where can I get the get the metal & rubber wraps that hold the leaves together? | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Maybe my truck is to old, what are these rubber wraps on your springs like???
DG
Denny G Sandwich, IL
| | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | It is a metal band with a rubber pad under it. They rust away or get left of during spring maintanence work. Over time, the leaves in the spring shift side to side unless they have something to keep them stacked atop each other. The bands hold the leaves in alignment.
I've never been to a spring shop. Sounds like a plan. Thanks | | | | | Joined: Feb 2000 Posts: 5,191 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,191 | Head over to KC Spring, they are down on 16 or 17th street in Kansas City. They have been there since the '20s. Joe | | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | Thanks Joe, I'll be going over to Jim Carter's next week, I can stop at KC Spring on the way. | | |
