1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#611779 01/20/2010 4:53 PM
I'm putting my springs back together. Where can I get the get the metal & rubber wraps that hold the leaves together?
From a spring shop
Maybe my truck is to old, what are these rubber wraps on your springs like???
DG
Denny G
Sandwich, IL
It is a metal band with a rubber pad under it. They rust away or get left of during spring maintanence work. Over time, the leaves in the spring shift side to side unless they have something to keep them stacked atop each other. The bands hold the leaves in alignment.
I've never been to a spring shop. Sounds like a plan. Thanks
Head over to KC Spring, they are down on 16 or 17th street in Kansas City. They have been there since the '20s. Joe
Thanks Joe, I'll be going over to Jim Carter's next week, I can stop at KC Spring on the way.
