5 members (DoubleB, EchoBravoSierra, frogfarmer, TooMany2count, Achipmunk), 55 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
#61153 05/30/2006 11:43 PM
Hi, I recently got a '61 K-10 with 235/4 speed on the floor. The truck will shift into reverse, 1st, and 2nd with the truck running or off, and can be driven in those gears, but in the 3rd and 4th positions, it's like there is no gear there. The truck was used in a lumberyard, and sat for a long time, so those gears probably weren't used much when it WAS in operation. the transfer case shifter shifts smoothly through all the 4wd ranges. Any ideas? I drove it in a field in hopes things would work loose, but no results there.
#61154 05/31/2006 12:12 AM
You'll probably have to pull the top plate of the trans. to see if it's in the shift forks or in the gears and syncro's.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#61155 05/31/2006 1:48 AM
Thanks Scott, I figured that would be the next step, just wanted to make sure. I'll report back with my findings.
