7 members (Hotrod Lincoln, bobfake, GRNHydra, tclederman, Woodcmiami, Otto Skorzeny, 2-Ton),
43
Mod | | | Forums66 Topics128,091 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Hello all! This is my first post as I'm a new member. Question: I recently bought a new 6v alternator for use with my 1946 1.5 ton. I have decided to convert to 12v. Can I take the alternator to an electric shop and have it changed over to 12v? I really don't want to buy a new 12v Alt. and be stuck with a 6v I'm not using. Thanks | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Welcome to the 'bolt. May I ask why are you wanting to go to 12 volts?
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | What brand is the alternator? It would seem that the only conversion you would need to do would be to install a rotor with a 12 volt field winding instead of the 6 volt one. The stator shouldn't require any alteration. Is it internally-regulated? If so, the electronic regulator will need to be changed, also. Jerry
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | A fellow bolter might like to have a 6V Alt. on his vehicle....then buy you a new 12V is thats the way you want to go.
| | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Simply put, it's makes everything so much easier form starting to lighting. I converted my Two 1947 Willys jeeps and I'll never go back! I keep my vehicles period except for the 12v conversion. 12v items are less expensive than the 6v counterparts. The 46 truck needs to be rewired as the old is in pretty bad shape. If I'm going to rewire, then I'll go ahead and convert. | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | I bought it from "Jim Carters" and I think it came from a place in Kansas. It's written on the box. | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | That's a good Idea. It would probably cost me more to convert it than to buy another one. Thanks | | | | | Joined: May 2008 Posts: 40 Apprentice | | Apprentice Joined: May 2008 Posts: 40 | In the alternators I work on the 12v rotor is still used for 6v charging only the regulator is changed, a good quality 12v regulator is all you need if you have a standard internaly regulated 10-12SI Delco alt. $6.00 for a 12v reg up here. | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | captaintractor or anyone, Do you have a part number and brand for a 12v regulator either one wire or two, I'm not picky!!! The 10SI has a 12:00 position for the DA plug. Thanks | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | If all you have to do is change the internal regulator,i would go that route.They are simple to take a part,hardest part is loading the brush's,and that's not hard .You can also change the clock position when putting it back together. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2008 Posts: 40 Apprentice | | Apprentice Joined: May 2008 Posts: 40 | WAI global/Transpo part number is D101HD for the heavy duty version, D10SE for self exciting, but the SE's don't work in every unit depends a lot on how the stator is wound. theres also a D10AC self exciting. old Delco number is 1116392, 1116423. If you think you may have a 6volt rotor (never seen one) hook an amp gauge to a 12 volt battery and touch each lead to each of the slip rings on the rotor. your amp gauge should show about 3-5 amps. a 6v rotor would draw twice that at 12v say 6-10v. then find a good used rotor or new, let us know what you find. | | |
