| | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 35 New Guy | | New Guy Joined: Dec 2009 Posts: 35 | What should I use to re wire my truck. Should I go with a reproduction or one of the aftermarket ones. What is the easiest and most economical. I have looked at LMC and Brothers, also looked at the Painless Harnesses. Any suggestions. | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | what year truck? gauges or warning lights? | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | | | | | | Joined: Dec 2009 Posts: 35 New Guy | | New Guy Joined: Dec 2009 Posts: 35 | I have a 65 with gauges and I also have back up lights. | | | | | Joined: Aug 2009 Posts: 15 New Guy | | New Guy Joined: Aug 2009 Posts: 15 | Here is an excellent link from one of the "other" Chevy Sites. http://67-72chevytrucks.com/vboard/showthread.php?t=375602I too think you get what you pay for. Just try to buy USA made stuff, you will be happier. Good luck, Taclem | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I personally prefer the aftermarket factory reproductions wiring harnesses. They are specific to the engine type and dash cluster, whether gauges or warning lights. They are "plug-n-play" with the correct connectors, wire colors and gauges. The entire wiring system is available, via 11 different harnesses, so you only have to purchase the harnesses that need attention. Try: www.bowtiebits.comwww.lmctrucks.comwww.classicparts.comwww.truckandcarshop.comwww.oldchevytrucks.comThere are many others, but I have personal experience with these...with positive results. | | |
