5 members (Charles in CA, klhansen, FishinToms53, Hanks custodian, 5 Window 9434), 53 guests, and 0 robots.
Topics128,049
Posts1,055,634
#610624 01/16/2010 9:06 PM
What should I use to re wire my truck. Should I go with a reproduction or one of the aftermarket ones. What is the easiest and most economical. I have looked at LMC and Brothers, also looked at the Painless Harnesses. Any suggestions.
rodwst #610652 01/16/2010 11:13 PM
what year truck? gauges or warning lights?
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
rodwst #610671 01/17/2010 12:31 AM
I have a 65 with gauges and I also have back up lights.
rodwst #610805 01/17/2010 6:00 PM
Here is an excellent link from one of the "other" Chevy Sites.
http://67-72chevytrucks.com/vboard/showthread.php?t=375602
I too think you get what you pay for. Just try to buy USA made stuff, you will be happier. Good luck, Taclem
taclem #610809 01/17/2010 6:26 PM
I personally prefer the aftermarket factory reproductions wiring harnesses. They are specific to the engine type and dash cluster, whether gauges or warning lights. They are "plug-n-play" with the correct connectors, wire colors and gauges. The entire wiring system is available, via 11 different harnesses, so you only have to purchase the harnesses that need attention.
Try:
www.bowtiebits.com
www.lmctrucks.com
www.classicparts.com
www.truckandcarshop.com
www.oldchevytrucks.com
There are many others, but I have personal experience with these...with positive results.
