| | | Forums66 Topics128,281 Posts1,058,478 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 18 New Guy | | New Guy Joined: Dec 2009 Posts: 18 | the wife don't like the clutch, I told her it was designed back when broads were not allowed to drive, you'll get used to it.
Is there a kit, or has someone added a Hydraulic clutch to one of these old trucks. 1965 C20
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | So how is the black eye doing? | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | what does she not like about it? ron | | | | | Joined: Dec 2009 Posts: 18 New Guy | | New Guy Joined: Dec 2009 Posts: 18 | it's too hard, my leg shakes if I try to hold it in. I doubt I'll change it from Stock, just pondering. Besides women don't belong behind the wheel of Vintage Iron. Quittin' time, see ya round | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Changing to hydraulic wont help. The pressure plate is probably too stout. The rebuilt ones we used to get you never knew what they were going to be like. Practically all clutches we gewt now are new & more consistant. There is 2 grooves in the clutch fork. If you use the outer one you can gain some leverage. Check all the linkage to make sure its not wore out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2008 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 69 | Like wrenchbender said, I don't think a hydaulic setup would be any easier. If you don't use the truck for pulling heavy loads all the time, you may be able to put a smaller clutch. You most likely have the 11" clutch in there now, and a 10" would probably do all you need. Alot of the flywheels were drilled for both patterns, you could drop the dust cover and see if yours has both. Just a thought. Best of luck.
TruckNut
Be kind, courteous, cheerful and helpful - And someone will take advantage of you.
"Quiting smoking is easy, I've done it hundreds of times." Mark Twain
| | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | Here's a link to the hydraulic setup I used in my 1960. Something similar could easily be done in a 66. I found the components I'm running provide a considerably lighter pedal pressure than the original setup. I'm running a Centerforce clutch, Girling master cylinder and a Novak slave cylinder. I have chronic back pain and a bad knee, so a light clutch is essential to keeping a stick shift in my rig. http://www.sixty7ss.proboards.com/index.cgi?board=engine&action=display&thread=666 | | | | | Joined: Mar 2009 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 45 | Besides women don't belong behind the wheel of Vintage Iron. Quittin' time, see ya round I think he's just scared his wife will show him how to properly drive the beast.... I know my wife with her 63 could make him look bad. Didn't someone once trash Shirley Muldonwney ??? | | | | | Joined: Dec 2009 Posts: 18 New Guy | | New Guy Joined: Dec 2009 Posts: 18 | [quote=Kawboy]
I think he's just scared his wife will show him how to properly drive the beast.... I know my wife with her 63 could make him look bad. LOL I asked for it but I doubt there are many that out ride, out drive, out jump or out anything that has an engine, wheels or a track. Sorry for the chauvinistic remark, I'll leave the broads out of my postings from here on in. I am going to leave the clutch as is, she is a farm girl and will learn to handle it | | | | | Joined: Mar 2009 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 45 | It's all in fun...however, if the time comes, don't look my wife in the eyes..... just hang your head low and say "yes Mam" | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Check the strength of the spring on the fork-to-the-frame and on the pedal-to-the-mounting brace. One may be too strong and the other too weak or the reverse. This may help a little.
I have had a few that are very stiff and a few that seems entirely too soft, so I think there are many variables, that may dictate the stiffness.
Good luck. | | |
