| | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 72 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 72 | How is the Fresh Air Heater different from the "standard air heater"?? Thanks Guys! | | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | fresh air heater can pull air through louvres on the side of the truck or recirculate air...the std heater just recirculates air in the cab
Bryan 1954 3104 235 "AD" L-6 3-on-the tree
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The 1953-55 Fresh Air heater (sometimes called an Air Flow heater) also had an interior door to allow "recirculation" of interior air (this door was not found on 47-52 Fresh Air heaters).
| | | | | Joined: Nov 2009 Posts: 72 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 72 | Brad,Bryan and tclederman, Thanks for the information you guys provided. Now I know for certain that I have the Fresh Air Heater in my truck. I am under the impression that the hoses were disconnected because the core was leaking. Do you guys know if a radiator shop can repair the core if such is the case? Thanks! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Depends on how bad it is rotted out. I've seen many of them repaired. I have no got that far along on my project yet but I would also think if you go to a shop that they can find a new one that will fit or one that can be modified to fit....which is what I recommend. No use in having this kind of problem down the road after we have spent quite a bit on other things!! | | | | | Joined: Nov 2009 Posts: 72 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 72 | Achipmunk,I'm thinking along those lines too. I'd hate to leave it be and then find out it leaks likes mad. Appreciate the help,Thanks! | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I just had my heater core done this summer on my 52 and they recored it with modern core and used the top and bottom of the old one they looked for a long time to see if there was a core that would fit but there is nothing "new" so I ended up getting it recored if the shop does a good job it will be just as good as a new one ,it's not cheap but there is not much you can do about it.
Pete | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Just an observation: leaks can be at the core, the heater control valve (if equipped,) the hoses, and the connections.
Bill | | | | | Joined: Nov 2009 Posts: 72 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 72 | Pete52, I called a few radiator shops hoping to recore my Radiator, and the price they quoted me was more than if I would have purchased a new one. I am aware that it will cost me a shiny wooden nickel. Thanks.
TxLaTx, I will be purchasing the heater hoses and reconnecting them. It is equipped with a heater control valve, and so I will keep an eye on that as well when I make all the connections and turn up the heat.
Thanks. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | You were asking about the heater core,you can't buy a new one so they kinda got us over a barrel,but I am surprised that you can't get the rad. recored for cheaper than a new one.In my area rad shops I guess are cheaper.
Pete | | | | | Joined: Nov 2009 Posts: 72 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 72 | That's why most people move out of California, way expensive! Like I mentioned, I did my research on the Rad and if I am going to pay high dollar, it might as well be for a New one! It's the cost of rebulding a Classic.. | | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | If you can get the heater cored repaired Tom Myers in Miami Ok has repaired cores on the shelf, for both the recirc and fresh air type. | | | | | Joined: Dec 2009 Posts: 6 New Guy | | New Guy Joined: Dec 2009 Posts: 6 | I recently purchased a 55 1st series and I have a big square heater that is under the dash that is too bulky. I was wondering if it was a stock heater or if it is a replacement of some kind that I can get rid of without worrying too much. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That is an aftermarket, non-GM heater (at least not from 1955).
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I would look for a tag there were lots of aftermarket heaters available back then. Sears, Montgomery-Ward, Sunbeam ect. Factory heaters, Air-Flow or recirculating were big bucks in dollars of the day not everybody could afford factory or dealer installed. | | |
