9 members (fonz8261, 55shaker, Guitplayer, Cletus1950, RoadsScholar, Otto Skorzeny, carbking, Greg_H, 1 invisible),
121
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,131 Posts1,056,721 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60790 05/23/2006 3:29 PM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I will be putting a small block V8 in my 52 1/2T panel soon. Is it possible, or is there a regular exhaust manifold that I can use and not HAVE to move the steering box. The previous owner rebuilt the front axle ect including new drums/brakes and I would like to leave the steering as is. From reading I see a 19?? Toyota truck gear box is best but is there a "rear exit" manifold or some other one that will work with existing steering box? I have ran across a nice (if there is one) 305 engine with 14,000 miles on it that I will be using. Any help will be appreciated gang or just tell me it can't be done??!! Thanks | | |
#60791 05/23/2006 4:11 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Early (55-56) log style manifolds might be what your looking for. The ports may be a bit small for late model V8 heads however. | | |
#60792 05/23/2006 4:44 PM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | Does it have the 305 log manifold that drops between 5 and 7? I have seen those work on a couple of occasions, but I think it is try and see rather than a sure fit. | | |
#60793 05/24/2006 3:38 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | It did not come with the manifolds. I was thinking along the lines of moneypit about using one off an earlier model like the small ones off a 265 or 283 or perhaps one that has the outlet at the back. I just thought perhaps someone else had done it and would save me some time. I don't mind the leg work but all "short cuts" appreciated. Should I come up with something I will surely let the Stovebolt know it. It will be a little time before I get there but I will do it!!! Thanks 4.384toy for your input. I can probably run across a 305 fairly easy. An old friend of mine has an old junk yard type garage and probably has some of each. Thanks guys. | | |
