4 members (Maybellene, klhansen, 2 invisible),
87
Mod | | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Does the oil air cleaner come apart? If it does, how do I get it apart without breaking it? I've done a search and some guys have gotten them to open up, but I can't seem to figure it out. Thanks for any help.
Mark
1951 Chevy 3100 Some days you get the bear. Some days the bear gets you.
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Not really, just the two main parts come apart, but I am sure you already know that. | | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Brian,
Thanks for the reply. I was refering to the top piece coming apart. How do you clean the fabric without taking it apart? The decal is still on the top and it says to use kerosene. Do you just pour it in and let it drain?
Mark
| | | | | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | If the paint on your air cleaner is not pristine - just put kerosene in the bottom and replace the top and let sit for a day.
Air dry the element to make sure all the kerosene is gone before replacing the oil.
I wanted to be careful with my paint - and wanted a deep cleaning, so I used a plastic pail to put the kerosene level just below the top of the filter (top part only in the pail). | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I too was wondering if they could be forcably taken apart. I want to gut one and put a paper element in mine so all of the air is getting filtered. Anyone tried this? I don't like the looks of those cheap "Moroso" type air cleaners. Scott | | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Scott-
Search oil air cleaner. There are a few that have done just what you want to do.
Mark
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Thanks, I'll be on it as soon as I find the time. Scott | | |
