3 members (TUTS 59, Hugh63c10, Phak1), 212 guests, and 3 robots.
Topics128,089
Posts1,055,988
Members48,430
Junior Member
Junior Member
Hey bolters,
As some of you may know I took of my head to replace the head,manifold and all other gaskets om the head. when I flipped the hed over to inspect the valves three were cracked and all of them looked pretty bad .The cylinder walls looked great though. So I decided its time for a rebuild. The reason for doing this in the first place was because it poped or missed not really backfire.I also had a spare head and the machine shop said the original was cracked and the spare wasnt so the rebuilt it instead. Now it still does the same stuff? any suggestions.
If ain't broke Break it and fix it.
For the popping and missing check the distributor for wear on the advance. If the distributor can move back and forth a bit because of a worn lever, it can cause those symptoms too.
Ex Hall Monitor
Ex Hall Monitor
Time for a good look at the timing and the ignition system.
Riding in the Passing Lane
All good sugestions. Also look for lean fuel mixture.
1972 Chevy c10 Cheyenne Super
Junior Member
Junior Member
Thanks Builder,
I think it could be the vacuum advance mechanism because I can turn the distributor about a 1/2 inch either way. I will order it tommorow and keep yall informed.
Thanks again
Slade
