1 members (1 invisible),
89
Mod | | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60554 05/16/2006 1:11 PM | Joined: Oct 2004 Posts: 27 Junior Member | | Junior Member Joined: Oct 2004 Posts: 27 | Hey bolters, As some of you may know I took of my head to replace the head,manifold and all other gaskets om the head. when I flipped the hed over to inspect the valves three were cracked and all of them looked pretty bad .The cylinder walls looked great though. So I decided its time for a rebuild. The reason for doing this in the first place was because it poped or missed not really backfire.I also had a spare head and the machine shop said the original was cracked and the spare wasnt so the rebuilt it instead. Now it still does the same stuff? any suggestions.
If ain't broke Break it and fix it.
#60555 05/16/2006 1:28 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | For the popping and missing check the distributor for wear on the advance. If the distributor can move back and forth a bit because of a worn lever, it can cause those symptoms too. | | |
#60556 05/16/2006 4:11 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Time for a good look at the timing and the ignition system.
#60557 05/16/2006 10:17 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | All good sugestions. Also look for lean fuel mixture. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#60558 05/17/2006 2:48 AM | Joined: Oct 2004 Posts: 27 Junior Member | | Junior Member Joined: Oct 2004 Posts: 27 | Thanks Builder, I think it could be the vacuum advance mechanism because I can turn the distributor about a 1/2 inch either way. I will order it tommorow and keep yall informed.
Thanks again Slade
