| | | Forums66 Topics128,163 Posts1,056,962 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 5 New Guy | | New Guy Joined: Dec 2009 Posts: 5 | need to find out how to stop trans oil from leaking out the rear of short drive shaft tube on rear of trans. took shaft down and found no seal on front or rear. the doggy doctor | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | What kind of truck do You have ?
Pete | | | | | Joined: Dec 2009 Posts: 5 New Guy | | New Guy Joined: Dec 2009 Posts: 5 | my pickup is a 1941 3/4 ton with a 3 speed has a open drive shaft on the rear and a closed on the front it is leaking on the raer of the front section | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Dec 2009 Posts: 5 New Guy | | New Guy Joined: Dec 2009 Posts: 5 | extreme gabster great info on driveshaft leak i'm a retired mack mechanic didn't want to ruin anything taking it apart. the old girl has been in the family since new. thanks much | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | See if any of these look familiar xxxx, this is from a stock 1950, 3600 with a 4sp. SM420. http://www.pbase.com/dennygraham/driveline Denny Graham Sandwich, IL
Denny G Sandwich, IL
