0 members (), 110 guests, and 2 robots.
Topics128,162
Posts1,056,924
Members48,458
#604545 12/26/2009 5:20 PM
need to find out how to stop trans oil from leaking out the rear of short drive shaft tube on rear of trans. took shaft down and found no seal on front or rear. the doggy doctor
doggy dr,
Just to be sure that responders are going to give info pertinent for your truck, you should put your truck year/size in your profile and in your post.
Assuming you are referring to a torque-tube 47-55 truck, you do indeed need seals at three places around the u-joint ball/bell. This is described in the transmission section of the Shop Manual.
http://www.classicparts.com/1947-54-U-Joint-Ball-Gasket-Seals/productinfo/92-111/
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0712.htm
What kind of truck do You have ?
Pete
my pickup is a 1941 3/4 ton with a 3 speed has a open drive shaft on the rear and a closed on the front it is leaking on the raer of the front section
extreme gabster great info on driveshaft leak i'm a retired mack mechanic didn't want to ruin anything taking it apart. the old girl has been in the family since new. thanks much
See if any of these look familiar xxxx, this is from a stock 1950, 3600 with a 4sp. SM420.
http://www.pbase.com/dennygraham/driveline
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
