1 members (Steelonsteel),
141
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,289 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60386 05/12/2006 1:21 PM | Joined: May 2006 Posts: 2 Junior Member | | Junior Member Joined: May 2006 Posts: 2 | I need to know if a TH350 will bolt to a 235 and if so what type of adapter, flexplate, starter, and shifter is recommended........Thanks | | |
#60387 05/12/2006 1:30 PM | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Yup.
dunno about the details though.
You might try the 'search' function.
-W | | |
#60389 05/12/2006 6:14 PM | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | | | |
#60390 05/12/2006 6:37 PM | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Here's another: Bendtsen\'s . But to answer the basic question the THM will only go on the back of a 235 (216, 261) with an adapter.
Professional Novice
#60391 05/14/2006 4:17 PM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Your in luck, a small outfit by the name of General Motors just happened to make such an adapter. The best place to find them is on pre 63 chevs with the 235 and cast iron powerglide. It seems that more 61 and 62's were bought with glides than previous years--I guess drivers were getting lazy.
Evan
#60392 05/14/2006 6:42 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | The non-smart a$$ answer is that there are a few problems with putting a TH350 of 700r4 behind a 235/261:
First, auto's need a flex plate, not flywheel- No big deal to get one of these.
Second, motor mounts- When you ditch the bellhousing you'll need to figure out how to mount the engine. Some outfits do make a piece that'll bolt where the bellhousing was and provide mounts. There are probably some other options too.
Third- shifter- you should be able to work this one out- I like the TH350 shifter that sticks up through the floor like the original 4-speed shifter- keeps the inside stock looking,which I like.
Fourth- You may need a bigger radiator and definately will need to install a tranny fluid cooler.
Stovebolt engine co has a kit for putting the TH behind a bolt. I've read they get it from Buffalo and you can get it from the supplier for less= you'll have to figure that out for yourself.
